Just wandering why you guys think chevy hasnt put an overhead cam in the vette by now?? I would have thought they would have to bring the vette into the next generation of sports cars
The product team wants the Corvette to have a low cowl and engine compartment side rails. The cam in block/push rod engine design provides for a lower engine height which allows for a lower hood, cowl and side rails. The Corvette's cousin, the XLR, with the twin dual OHC design (Northstar), has a little higher cowl. Besides, the push rod LS7 is SAE rated at 505 hp, not too bad!
Correct me if I'm wrong but wasn't the 1990-1995 ZR1 DOHC??
There is nothing "next generation" about an overhead cam. Duesenburg had them in 1929.
The new LS series of engines is far more sophisticated than the LT5 engine in the ZR1. More power, less volume, lighter, better fuel consumption, and a wider smoother power band.
Just because it's "European" doesn't make it better!
Overhead cam is old technology. Chevy uses the newer cam in block design to make the engine lighter and more compact. Chevy once did bow to pressure from the fans of the older overhead cam technology with the LT5 used in the ZR-1. But it was heavier, larger, and less powerful than the LS2/LS7 series of engines, and was abandoned.
People have been brainwashed into thinking the size of the engine is only related to the displacement. OHV allows GM to get more displacement out of a given overall physical size, which offsets the gains in HP you get with a OHC 4 valves/cylinder engine. The 5.7L LS1 OHV engine has higher displacement and is smaller and lighter than both Ford and Cadillacs 4.6L DOHC V8s. Granted I will admit, all else being equal, the OHC design is prone to being a little smoother.
I read an article where the author claimed(and had pictures showing) that the Ford 5.0 pushrod engine was hardly any bigger in overall size than the Ford 2.5L duratec DOHC V6. At an auto show I saw a 5.7 L LS1 pushrod engine on display in the Chevy section and I saw a Nissan 3.5L OHC V6 engine on display in the Nissan section. I was shocked that they looked similar in overall size. On another forum there was a heated pusrod vs OHC debate that came down to a few people providing data showing the 3.5 L Nissan and 5.7L Chevy engine not being that far apart in size and weight.
To sum it up I think GM is just as clever as everyone else in engine design.
as far as push rods, well It works very well, why change it?
too
Please keep it the way it is. I'm quite happy that I don't have to do silly things like adjust valve timing on an OHC. Pushrod is better in many ways. It even offers some protection against overrevving (the valves will just float above a certain point). Not that it is much of an issue with a rev limiter, but more protection is better than less.
I agree with everything you said, except this. What is your source for this? All else being equal, there is little to choose between them in smoothness. A 90 deg V8 is inherently smooth (as is an inline 6), unlike V6s that have second order vibrations without balance shafts. Any "lumpiness" comes not from the choice of valve activation, but from cam profiles, etc. Even choice of firning order has a greater effect on smoothness than the pushrod vs. OHC decision.
In addition, the shorter timing chain of a pushrod design eliminates one potential source of vibration (although companies like Toyota take a lot of care in this area).
1. If you're curious what an DOHC multi valve engine feels like, test drive a Carrera 997. You'll find you need great handfuls of revs before it starts to pull. There is no down low grunt.
2. Torque is what really makes a car move, and the OHV engine gives you lots of torque both low down and all through the rev range. After you get out of the 997, test drive a C6 Z51 MN6. Just put your foot down and hang on to your hat. And you'd better have it pointed pretty much in a straight line before you light it off. I'll take an OHV mill with 400 ft lbs and 400 bhp anytime over a smaller, peaky DOHC design. Remember, Ford clobbered Ferrari in the mid 60's in a similar OHV/DOHC duel. And the OHV C6R Corvettes did the same thing to all the DOHC GT contenders at this year's LeMans 24.
There is nothing like the torque monster that is called a small block chevy. :
I have given several 996 and other p-car drivers rides in my car on the track. C5 with 400 rwhp and 405 rwtq. There is nothing like shifting from 2nd to 3rd at 120 mph and having that p-driver passanger lunge forward in the seat( when I shift out of 2nd) only to be pushed deep into the passanger seat when 3rd gear and all that torque takes over.
and the comments are," No wonder I cant catch you when shift to 3rd."
Hard to argue with the results Chevy has acheived with the LS2, 6500 PRM R/L, and LS7, 7000 RPM R/L; net HP output of well over 1HP / CID; smooth power delivery and broad torque band; outstanding fuel economy; compact, simple and lightweight and relatively inexpensive. Chevy has pretty much perfected its small block V-8. If it an't broke don't fix it!
