Cleaning your engine
Old Jul 6, 2005 | 12:16 PM
masihman's Avatar
masihman
Default Cleaning your engine
Ok, I was reading the owners manual and it warns about spraying water in the engine compartment due to the air filters. I used to wash my Z-28 engine bay and then spray it down when it was cold. The C6 engine gets very dirty very quick and I don't even drive in the rain. I'd like to keep the engine bay looking clean. How can I do this without getting the air filters wet. Any suggestions?
Old Jul 6, 2005 | 12:18 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Just don't spray it them directly.
Old Jul 6, 2005 | 12:25 PM
63C663's Avatar
63C663
Why not just take the air filters out before cleaning?
Old Jul 6, 2005 | 12:31 PM
masihman's Avatar
masihman
I suppose that would work. Does anyone else do this or am I the only one that cleans my engine. Based on some of the pics I've seen I'd think many of you guys do this. Is there anthing else in the engine bay I'd have to worry about.
Old Jul 6, 2005 | 12:35 PM
lager99's Avatar
lager99
St. Jude Donor '06
Then you would for sure get water in the intake. The idea is that the filter is uncovered & you will soak it, it will suck water into the engine. Spray the engine with a light mist, do not directly pressure wash anything on any vehicle.
Old Jul 6, 2005 | 12:36 PM
Michrider's Avatar
Michrider
Everything electrical.
I wouldn't spray with a hose. I know a lot of people do it and get away with it. But I've seen many times and postings where something gets screwed up hosing water in the engine compartment.
I just wipe down with a damp cloth. Then wipe most things with a little armor all or similar on a cloth. There is some pretty expensive electronics under there.
Old Jul 6, 2005 | 01:12 PM
Black-Bullet's Avatar
Black-Bullet
Old Jul 6, 2005 | 01:17 PM
Guitarstar's Avatar
Guitarstar
Here in Vegas where its dusty I can not believe how clean my engine stays. I wipe it down twice a week & use FT21 on the hoses. She is still looking new.
Old Jul 6, 2005 | 01:20 PM
chris36053's Avatar
chris36053
I use a product called Corkay (spelling?) on the engine, also use a vaccum with a soft brush head.
If you have to spray water in the engine bay then take a small white garbage bag and wrap one around each filter and reinstall them. Just don't forget to take them out after your done.
Old Jul 6, 2005 | 01:34 PM
hamshog's Avatar
hamshog
Over 5000 miles and my engine is like new. I wipe it down once and while but that is all.
Old Jul 6, 2005 | 03:31 PM
masihman's Avatar
masihman
Thanks for all the feedback guys.
Old Jul 6, 2005 | 08:28 PM
purple heart's Avatar
purple heart
Starting with a clean engine is half the battle; keeping it clean is the other half. I use hand towels and either spray water on the area to be cleaned (engine MUST BE COLD) or have an extremely damp towl and another one to follow-up to dry. Wipe it all so it looks uniformily clean. I usually do this after every time I wash the car but at least once every month or two go in and just concentrate on the engine and bay. If you stay on top of it, its easier than most people think.
In fact, today, I washed the underneath by spraying it with the hose from both the left and right sides while lying on my back along side of the car. I then dried it off with hand towels but mind you, don't wear nice shirts or shorts/pants. You're gonna lie in water so expect it. Start on one side behind the front wheel, sliding down the side of the car to the back end, do under the back end and then lie down behind the front or rear wheel, reaching under the car with one arm and a handtowel drying it off till you reach the back end. This i admit only do about every 2 months or when a big show is coming up. this way, it cleans up nicely and fast.
Old Jul 7, 2005 | 12:17 AM
LS WON's Avatar
LS WON
Default You can also use an air compressor for those tight spots.
Old Jul 7, 2005 | 01:05 AM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
I use air and damp wipe.
Old Jul 7, 2005 | 02:24 AM
LS WON's Avatar
LS WON
Default On my other car I use Gunk that stuff smells good and it cleans but
if you do get the water where it doesn't belong you could end up with problems like a short. The Corvette is full of electronics so Gunk might not be a good thing for this.
Old Jul 7, 2005 | 11:53 AM
jjohn918's Avatar
jjohn918
Make sure the engine is running when you spray it down. The engines are designed to be "water resistent" when running, however they don't do as well when they get wet when they are off.
To Cleaning your engine
