From: Buena Park, CA I seem to have left my electrolytes with your daughter
need help removing instrument pod/bezel
ok, I've got the console and radio/shifter trim out, so how do I do the instrument pod/bezel? is there a trick? just pull? take apart lower dash? I'm crawling through my car right no, so any help would be most apreciated.....I'll send you a beer.
I saw a post a couple months ago that supplemented the install instructions that came with the trim (mine came with none)
Woody its very easy!!! Just pull on the corners on the bottom of the cluster..Its a Bit tight but it will pop Out...then when you have both bottoms out....You can pop it out from the GLASS AREA by the Speedo..Pull down...There are 2 Clips there....Hope this help...Message me i will be here for a Bit...
