Just got a REALLY HOT tip from a mechanic about DBS in our 2005, C6, 6-speed Vets. Have you programed your vehicle to activate your home garage opener? Does your garage door have rolling codes? If the answer is YES, this may be the reason our batterires are dieing. The mechanic told me that he has seen this in some Cadillac and '05 Vets. He says that since the door opener has rolling codes, it may be communicating with our Vets even though they are shut down. It takes about two weeks for my battery to die, which the mechanic said is about the right timing for the door opener to drain the battery. I'm going to deactivate my opener RIGHT NOW!! I'll keep all Vet owners posted as to the progess of lack of. Good Luck.
Interesting. Well, to my knowledlge, only the 1SB (3LT) cars come with the garage door opener feature, so this would not explain DBS in the other packages.
Seems that the C6 in general is sensitive to various electronic issues... DBS is probably a function of several or many different things. But the more we know, the better!
Will be interesting to see if your DBS totally goes away once you deactivate the garage door opener. Best of luck!
I have the rolling code opener and have not had DBS. I have MN6 and a garage door opener that is programed. Had the car six months. Back to the drawing board.
I must call on the mechanics analysis.
The garage (homelink) unit would then NOT be the cause of DBS if the Vette were not in the garage (or proximity).
However, this same issue (DBS) has occurred EVEN when the vehicle is not in the garage (or proximity) for extended lengths of time.
Lastly, why doesn't this same occurance happen in other vehicles? As an example, I have a Durange ('05) that has sat for over 4 weeks in my garage. It has homelink, and the garage doors have rolling codes,
Yesterday I started the Durange - no problems.
Further, the homelink amperage 'draw' is just not sufficient to cause this issue during a two/three week period.
According to some surveys I have seen on this board and others the majority of DBS happens with the MN6. MXO's have garage door openers why don't they have the problem.
If it were garage door openers/homelink I would assume it would affect both vehicles equally.
Same here. Mine is one year old, never check the steering wheel lock, and have never experienced DBS. There has to be something more than just the garage door codes going on here.
I highly doubt the mechanic's hot tip!! I have had several cars with the Homelink System and I have rolling codes on my garage door openers. I have never had a problem with them. My new 06 has the Homelink as well.
The garage (homelink) unit would then NOT be the cause of DBS if the Vette were not in the garage (or proximity).However, this same issue (DBS) has occurred EVEN when the vehicle is not in the garage (or proximity) for extended lengths of time.
3 DBS's and home garage door opener does not use rolling code.
However, now that you mention it, my daytime office garage opener uses a rolling code, and I stopped using that garage about the same time my DBS's stopped last winter.
Good thought, but doesn't explain lack of DBS in automatics.
Also, I don't recall hearing about any DBS's away from home on this forum. Maybe I missed something?
Homelink doesn't draw any power unless a button is pressed on the opener. None. Zero. Zilch. Power to the circuitry is routed through the push buttons, same as any other remote door opener. Your mechanic should stick to mechanics and leave theorizing about electronic stuff to people who understand it.
I don't disagree with you, but this problem is quite odd, and may be related to an outside stray RF signal initiating some events leading to DBS. Something like rolling codes should at least be considered, although it doesn't explain the lack of DBS in automatics. Maybe that stray signal somehow muddies up the shifter's shutdown sequence.
Stray RF may indeed play a part, I know I've had issues with the fob related to stray RF, but DBS isn't related to Homelink. That puppy can't draw any power unless a button is pushed.
I've said all along that I think a number of different issues are getting linked under the heading of DBS. For sure we know that some C6s came from the factory with defective batteries. For sure we know some DBS incidents were operator error, ie failure to shift to reverse, leaving the courtsey lights on, etc. Likely there are many other causes too.
It is striking that most of the complaints come from those with the manual transmission. That would tend to indicate a problem in the shift to reverse and/or column lock areas, since the auto cars don't have either one, and don't have many reported cases of DBS. It is also noteworthy that GM has removed both from the 2006 cars. My personal hunch is that most of the failures are related to the column lock failing to engage. Either the solenoid sits there drawing power, or the computers fail to complete shutdown procedures when the lock doesn't engage properly.
We need a group of C6er's to NOT engage the steering wheel for say, a month and experiment.
Maybe your mechanic would serve you better by giving you a hot stock tip.
What I need is any kind of help or response from General Motors. They still will not admit that this DBS exist!!! Go to any dealer and ask someone in the Service Dept. ifs they have heard of it, or know anything about it-their answer is always been NO!!!!!
By that, I assume you mean turning the wheel until the wheel locks up. I never do that on my car. I have had two six speed C6's now, and they both sit in the garage during the week - every week, without being started. I have not had DBS in either of them.
Nope, I have 3 openers with rolling codes programmed on my Homelink-equipped MN-6 built in August 2004. 12K miles and no DBS ever.
I have not engaged my steering wheel lock in the six month's I have owned the car and no DBS. I do not turn off the radio or NAV before shut down either. I do put it in reverse and set the brake. Some car's have the problem other's don't.
I have had DBS 3 times and I live in the country and have no garage door opener. The nearest house is several hundred feet away. I still am suspicious of OnStar since it was about a half hour after I had words with them my car just woke up on it's own after being parked for two days. If not OnStar I think it is some randon cell phone paging or RF interference that can wake the car up. Just would like to know the differences between MN6 and A4 circuits. OnStar is nothing more than a Verison pager but I can't seem to get to the root of what circuits it can get to and activate in the car. Wish GM engineers would work with me a little on this. Let us know how your experiment goes.
I have had DBS before and after I started turning the wheel to let the lock pin engage. I never felt the engage made any difference since the thing should be released by a latching relay (the service manual accually shows it as a motor). Once released it will ride the steering shaft around so if the wheel is turned it drops in the slot. I think it's a good idea to test the fact that the pin has been released for piece of mind that the shutdown conditions have been met. Since it would surely be a bad thing if this pin were released when driving, the fact that you can feel it drop as you turn the wheel means you have met all the criteria of shutdown and most certainly being in reverse would be on the top of that list. This function is accually controlled by the "Steering Column Control Module"
