Question on Cags / Skip Shift
At 2XX miles I installed a CAGS Eliminator that took away the "Skip Shift 1-4" feature. Last Weekend at 2500 miles the Check Engine Light came on. I took it to my local GM Dealership this morning, and the only code showing is CAGS Malfunction. Does this mean that I did not receive the right CAGS Eliminator when I purchased it from Zips???
They re-set the computer, and it almost instantly came back on. Do I have to live with my Check Engine Light On???
Is anyone else having the same problem??
Thanks Forum for all the Help!!
Not sure where you bought your CAGS Eliminator from, but from what I've read here it is likely burnt out. That is why the car is throwing a code, it sees it as an open circuit, as if you just "unpluged" your CAGS. The eliminator is to fool the computer into thinking it is still there and working properly.
FWIW, I bought my CAGS from MidAmerica and it's been in for 8,000 miles with no problems.
Get a new CAGS and all should be well again....or learn to live with the light.
C2 of Year Finalist (performance mods) 2019
St. Jude Donor 03-'04-'05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I just installed it this morning. I am going to buy a backup now.
2020 C8 of the Year Finalist - Unmodified
Why bother. I bought an 05 Vert with the 6speed about two months ago and rarely (like less than 5 times) has the 1st to 4th light come on. I ordered a cag but it is setting in the garage and I don't see the need to put in on.
Originally Posted by The Saint
The whole skip-shift feature is idiotic and has no place in a high-performance sports car.
Originally Posted by jimbo1972
2.2k ohm resister works just fine from Radio Shack. I think a pack of 5 cost 99 cents.
havent had a problem yet....
jim
jim
Originally Posted by Miaugi
I have read this before and I'm sure it's quite accurate...but the "store bought" models also protect the two plug ends from getting wet, grimy and corroded.
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
I agree, its much neater to buy one. I just happend to have the resistors in my garage from my old Subby WRX. Figured i would try it, taped them up nice and thats the way it has been
Jim
Jim
