Paddle Shifter -problem
Old Oct 14, 2005 | 07:59 PM
dmeyers's Avatar
dmeyers
Default Paddle Shifter -problem
I drove the 06 with paddle shifters and I think GM missed the boat. The natural sport position is to have your left hand on the wheel and your right hand on the stick. I was taking turns hard on a great road in back country San Diego and it did not feel natural or fun. My friends BMW 530 has the sport mode and you just tap the gear shifter and it gives the old time stick feel. For 07 I would rather have radio controls on the wheel and tap the shifter to change gears.
Old Oct 14, 2005 | 08:02 PM
black783's Avatar
black783
Thanks for the report!!
To me though...just having the right hand in action isn't enough...that left foot needs to moving also.
Old Oct 14, 2005 | 08:17 PM
mj_duell's Avatar
mj_duell
St. Jude Donor '06
Did you have the Traction Control off? If Traction Control is
active, upshifts are delayed to increase your control of the
vehicle. This takes away from the overall feel.
--Mike
Old Oct 14, 2005 | 08:21 PM
SDCEB's Avatar
SDCEB
I don't know what you are talking about! I had a BMW 330 with the sport shift and an 06 paddle shift. There is no comparison! The paddle shift is much better and more natural. Maybe it is a presonal thing, but there is nothing "natural" about either position, it is just what you are comfortable with.
Old Oct 14, 2005 | 09:33 PM
donsar's Avatar
donsar
Take up the drums!!
Old Oct 14, 2005 | 09:40 PM
VET4LES's Avatar
VET4LES
A Corvette is meant to be shifted by hand and left foot.
Old Oct 14, 2005 | 09:46 PM
Hurricane's Avatar
Hurricane
Moderator
Cruise-In I Veteran
...unless it is an A6, in which case it is meant to be shifted by the paddles on the steering wheel!
Old Oct 14, 2005 | 09:51 PM
1C62NV's Avatar
1C62NV
I own a 05 VY z51 vert auto and my other sport cars are both sticks I chose auto in my c6 due to wanting everyday driver. I am also sceptical on the paddle shifter option on the c6 (dont get me wrong) I feel GM should not have rushed to offer such a system on a TOP NOTCH sports car being it was first introduced on a GTP Boneville and without having the experience of (FERRARI,BMW and AUDI ) to name a few which all use components by MAG MORELLI who has been developing the F1 style paddles for years. I hope the system GM incorperates works well and not cause any big issues. MHO
Old Oct 14, 2005 | 09:53 PM
blkc6z51's Avatar
blkc6z51
Old Oct 14, 2005 | 09:54 PM
Tropical'67's Avatar
Tropical'67
..........if it's an old Corvette. But not the C6.
Old Oct 14, 2005 | 10:22 PM
steve miller's Avatar
steve miller
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
how can you downshift the A6, and turn the wheel at the same time?
Old Oct 14, 2005 | 10:40 PM
Hurricane's Avatar
Hurricane
Moderator
Cruise-In I Veteran
Pull the right or left lever behind the steering wheel, I would imagine...
Old Oct 14, 2005 | 10:54 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The paddle shifters are not perfect, but some of the criticisms are slightly off base:
Proper high performance driving technique calls for downshifting while going stright, in the braking zone. Trying to shift (up or down) when you have the steering wheel turned enough that the paddles are hard to use, is normally poor technique.
Proper technique also calls for keeping both hands on the wheel until the shift is needed, then returning the right hand to the wheel immediately.
If you take the class at Spring Mountain or a similar place, they will rag you without mercy until you break the bad habits.
Not that I ever had any bad habits.
Of course, my wife might disagree...
Old Oct 14, 2005 | 10:56 PM
not08crmanymore's Avatar
not08crmanymore
Default shift
unless it is an A6, in which case it is meant to be shifted by the paddles on the steering wheel! that's funny!
Old Oct 14, 2005 | 11:29 PM
John Bravo's Avatar
John Bravo
Old Oct 14, 2005 | 11:54 PM
RandyMi's Avatar
RandyMi
I own an 06 530 and never use the gear selector to convince myself that it is a manual. It has a slight hesitation and is no substitute for a manual. I will be ordering an A6 and will probably for the first few weeks like with my Beemer, will toy with it. I buy an auto so I do not need to play with both hands and feet. In an Auto trans, I think it is dumb to be manually manipulating the tranny. I know in my BMW the performance is better letting the tranny do the work on its own, and will bet that will be the same case with the C6. Have not driven a 06 A6 and regardless how the paddles work, I could care less. I do feel that if you are looking forward to playing with the paddles, you should buy a manual. I have owned many manuals in the past, but due to performance of the 400 hp, the way the car launches as an auto, traffic, being lazy, liking to sit on an angle in the seat leaning on the center arm rest, and having my right hand free to feel up my girl.....I prefer the auto!!!!
Old Oct 14, 2005 | 11:59 PM
RBYCC's Avatar
RBYCC
How do you downshift any manual transmission while turning the wheel???
I don't think it's recommended if you've done any road racing.....
Two hands on the wheel at all times unless you're shifting while in a straight line !!!
Drive a course like Lime Rock....you enter the front straight from a down hill sweeper....upshift to top gear in faster cars, but begin breaking and downshifting to maybe third gear as you pass the timing tower and start seeing the distance markers leading you into the big bend sharp curve....hardly have time to think let alone take one hand off the wheel as you enter the curve. All your gears should be set and braking completed prior to entering the curve...if not you end up in the grass !!!
Ergonomically easier to downshift a paddle mount on the wheel as one or both of your hands are always in postion to hit the paddle ???
To Paddle Shifter -problem
Old Oct 15, 2005 | 12:01 AM
RBYCC's Avatar
RBYCC
Old Oct 15, 2005 | 01:30 AM
steve miller
What I meant was how do you do a hand over hand turn, and shift at the same time? Answer: You Don't!!
Old Oct 15, 2005 | 02:28 AM
LS1LT1's Avatar
LS1LT1
Exactly. Two hands on the wheel at all times is a good (and safe) way to be, most race car drivers do it that way (when they're not shifting of course) as well.
