Painted Fuel Rails & Engine Parts - DIY
#41
Anyone else DIY on your fuel rail covers? I so what to do mine but are not sure what color..
Is it hard to remove the FRC from the engine? Does it have torx or weird type of bolts or just regular nuts and bolts?
Also do Fuel Rail Coveres from other LS engines fit or swap out? Meaning can someone with an LS3 use LS7 or can an LS7 use LS2 covers?
I would think the mounting points are the same right??
Thank you all, this is a bad addiction to have..
Mine just poped off. They are held in basically with little poles that go into holes on the covers and are held in with rubber. I've taken mine on and a number of times w/out issue. Just be careful after you paint them around the fuel line. I scratched mine a couple of times and had to touch it up. Now I use painters tape to cover it.
It took about 1 hour to do the whole job.
I did red because it matched the color scheme of the car.
Hope this helps
