Window tinting caution
Old Dec 7, 2005 | 10:12 AM
jonesde2's Avatar
jonesde2
Default Window tinting caution
I've used a tinting shop for years and the work has ben great. I took my C6 coupe and the installer nearlly fiinted. He said the conture of the rear glass was as difficult as any car on the market. He went ahead and installed the rear, but it's looks like crap. Took him 5.5 hours to get it intalled. He's willing to work out the problem, and I hope he does. If it can't be repaired to look good I'm going to have it removed.
I really believe in these guys, but can't put up with a bad looking tint.
Old Dec 7, 2005 | 10:30 AM
BigJoe's Avatar
BigJoe
My tinter finished my C6 in less than an hour and a half. The C6 can't be any harder than a C5 and I had all 4 of my C5s done there as well. All perfect except around the dots, but that is expected and can be worked out after the tint is on. Sounds like your tinter just hasn't seen many C5/C6s in his shop yet.
Old Dec 7, 2005 | 10:39 AM
blkc6z51's Avatar
blkc6z51
Had mine done about a month ago, not perfrct around the dots,other wise it looks good. About 2hrs to install.
Old Dec 7, 2005 | 10:41 AM
Lusky's Avatar
Lusky
mine looks great, took him less than 2 hours
the dots came out better than on my C5
Lusky
Old Dec 7, 2005 | 11:10 AM
Velocity Jonny's Avatar
Velocity Jonny
Mine was perfect, except for dots, which were very good. 2 hours.
Old Dec 7, 2005 | 11:16 AM
C6 Strangebob's Avatar
C6 Strangebob
My tinter has a method that works perfectly on the C6 dots.
He uses computer software on a plotter to laser-cut the tint film. He applies the entire sheet to the hatch glass. Then 2 days later, he comes to your location and finishes the work on the dots. First he cuts out the part covering the dots. He then takes a long time to mask that area, and applies 3 coats of black engine enamel to cover the dot area. He's been in the business for 26 years and really took his time to make it look perfect. No overspray, no "gray patches" or condensation.
Jeff-Ohio's Avatar
Jeff-Ohio
I'm glad this thread got started. Is it possible to do the rear window in one piece, or did they join two separate sheets and try to hide the join behind a defrost line?
Old Dec 7, 2005 | 11:41 AM
VTLYNN's Avatar
VTLYNN
7th Gear
Who did your tint? I live in the DFW area and I am looking to get my windows tinted.
Old Dec 7, 2005 | 11:42 AM
Desmoden's Avatar
Desmoden
Default where are you?
I want to use your guy
Old Dec 7, 2005 | 11:56 AM
dark_phantom's Avatar
dark_phantom
From: Central Florida. Black Sheep Squadron Member. 465 rwhp & 477 rwtq
Cruise-In VIII Veteran
St. Jude Donor '07
I tinted mine 2 weeks ago and the tinter did the back in one piece it is not perfect but doesn't look to bad from a distance. It took him about 3 hours to do it. The final result was pretty good for the price.
Old Dec 7, 2005 | 11:58 AM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
no problem here, the back window was cut as one piece and the whole car took less than an hour.
Old Dec 7, 2005 | 12:12 PM
blkc6z51's Avatar
blkc6z51
Yes one piece
Old Dec 7, 2005 | 12:26 PM
BigJoe's Avatar
BigJoe
Alta Mere in No. Richland Hills, but they have other locations.
Old Dec 7, 2005 | 12:44 PM
C6 Strangebob
Scott at Speedy Tint Mesa AZ 480 570-8468
Old Dec 7, 2005 | 02:39 PM
jeffgdula's Avatar
jeffgdula
time to find a new tint shop. Alta Mere has always done good work for me. The hatch of my C6 looks great.
Old Dec 7, 2005 | 02:53 PM
mike1952's Avatar
mike1952
St. Jude Donor '04-'05-'06-'07-'11-'12-'13
as does my new Z06...Sunbusters....$349.
Mike
http://forums.corvetteforum.com/show...8&forum_id=100
Old Dec 7, 2005 | 02:57 PM
Lusky's Avatar
Lusky
back glass is one piece, came out great
back glass & 2 side windows $150.00
Lusky
To Window tinting caution
Old Dec 7, 2005 | 03:44 PM
SA HEAT's Avatar
SA HEAT
Originally Posted by mike1952
as does my new Z06...Sunbusters....$350.
Mike
Mike, is Sunbusters in Austin?
Old Dec 7, 2005 | 04:55 PM
mike1952's Avatar
mike1952
yes, 11655-C Research Blvd. in NW Austin. They used Formula One lifetime film. It is even covered for accidental damage.
Mike
Old Dec 7, 2005 | 06:49 PM
jeffgdula's Avatar
jeffgdula
Mike
sweet car. hopefully I'll see it on the road sometime (I still haven't seen a silver Z06 in person)
