The item that lifts your car that goes in the jack hole. If you have the one that's gold iridated from Mid America could you please measure the dia. part that goes into the jack plate hole! Have new Craftsman jack and before ordering the puk just need to know this dim. to see if it would fit....thanks
I just measured the diameter of the jack puck shaft that fits into the hole of a hydraulic jack. It is exactly 1.140" in diameter as measured with a good dial caliper.
I have several different brand hydraulic jacks and the jack puck fits nicely in all of them. The holes in my jacks are about 1.20" in diameter.
The "jack pucks" sold by Mid America are unique in that they have a shaft that fits into the hole of a hydraulic jack, as well as a shaft that fits into the hole in the car's underside. You can't get any safer than that. An earthquake could hit and there's no way the car could ever side off the jack. It's the most positive connection that can be made.
From: Heaven, for the climate; Hell, for the company
Didn't I see some pucks that had a "floating" flange on the part that fits into the rocker panel -- rather than a single dimension rounded rectangle-- there is a smaller diameter shaft and a top that matches the opening in the rocker panel, so the puck can be rotated 90 degrees to lock in place?
Me too. Actually mine are some type of composite. I like them because there is less chance of slipping than with the metal ones.
I got the plastic ones too. I installed them and they fit perfectly. One question though. I was going to use the jack to lift my car using one of the jacking points, and then use a jack stand under the plastic inserts. Before I do anything dumb...is this the way to use these inserts? Or do I place the jack under these inserts? I'm sooo confused (i'm a rookie)
Someone on this forum said that jacking pucks concentrate the pressure in a fairly small area and can dish the frame "like they do on the C5." So I asked on the C5 Forum if anyone had dished their frame with pucks and got several "yes" answers. Hmmm...
The C6 is pretty new, but can some of you guys put a careful eyeball on the frame and tell us if there is a slight deformation from pucks? Especially, I'd like to know if the BMW jack pads cause the problem, that's what I want to use.
My C6 doesn’t arrive for a few weeks.
I need to buy a new “low profile” jack.
With the “pucks” installed, how low does the starting point of the floor jack need to be to get under there?
I’ve seen low profile jacks that go down to 3 1/2” or 3 3/4”.
Is that low enough?
Is that low enough?
That jack height should work if you are jacking from the side (where the jacking pucks are installed).
if you are attempting to jack the front cross member to raise the front end, the critical low point is the center front air spoiler. Most owners address this problem by driving the front tires onto 2 X 12 ramps to raise the spoiler for clearance, but I found that method to be a PITA for a simple oil change and just raised the car for access from the side. If you are raising the car up on jack stands, you will need to raise the front first...raising the rear first reduces the spoiler clearance even further.
My preference would be to use the plastic pad for jacking, and to place jack stands under the front and rear suspension components...the vehicle weight is carried straight through to the jack stands in a more normal distribution. I also have a small voice in the back of my head saying "jack stands on plastic pads not a good idea", but that's just me.
Note that your owner's manual tells you to place your jack stands such that they are contacting TWO ribs of the crossmember components...I found this doesn't work so well in practice, because the rib edges aren't at the same height, but it works fair. IMO, it's a good idea to stay off the control arms and avoid contact with the bushings.
