Anyone Getting This Paint Problem?
Old Dec 19, 2005 | 09:34 PM
jim213's Avatar
jim213
My vert is lined up fairly well but I am still getting small chips even with the splash guards on the car. Some of that has to be from driving during the winter weather.
Old Dec 19, 2005 | 10:01 PM
Hoonose's Avatar
Hoonose
This problem was reviewed and discussed almost a year ago.
I forgot about it til this new thread.
Here's my grommet fix:
http://forums.corvetteforum.com/phot...cat/500/page/1
My body shop guy touched up the chips, when I had other painting to do.
I forgot that dang rubber grommet was even down there, til now!
Old Dec 19, 2005 | 11:15 PM
mnmvette's Avatar
mnmvette
No problem here, perfect alignment and not a single chip.
Old Dec 20, 2005 | 11:55 AM
aggie88's Avatar
aggie88
Nice, thanks. Can you tell me what kind of grommet you used?
Old Dec 20, 2005 | 12:11 PM
Hoonose's Avatar
Hoonose
I used a grommet that was to be inserted in a 1" firewall hole in my old Miata. I think a cable went through the center hole of the grommet, but that was too long ago to remember the details. I just trimmed it to fit and do it's thing.
There must be better and cleaner solutions by now.
Old Dec 20, 2005 | 01:35 PM
vetdude's Avatar
vetdude
Originally Posted by mlongo99
I have yet to see a C6 where these panels lined up properly.
...and some much worse than others. The most I've seen don't align at the leading edge of either door to the trailing edge of the front fenders near the top in front of the mirrors - rear edge of fender normally sits out about 1/4" from door edge. To me, there is no reason for the sloppy alignment. Even Hyundais have good panel fit for crissakes!
Old Dec 20, 2005 | 01:40 PM
Arthur6's Avatar
Arthur6
I as well as ALL my Corvette friends have it.
We put a peice of clear tape alone that edge. Change it every other wash, so far so good.
Old Dec 20, 2005 | 01:46 PM
Mel 2001's Avatar
Mel 2001
What kind or name of clear tape do you use?
Old Dec 20, 2005 | 01:48 PM
SC TROJAN GRAD's Avatar
SC TROJAN GRAD
Originally Posted by SA HEAT
I'm one of the lucky ones..... both doors and rear quarters line up perfectly on mine.
I dont have an issue.....body lines are all aligned....
Thats horrible....
Old Dec 20, 2005 | 01:57 PM
C8-Vette's Avatar
C8-Vette
Originally Posted by 66dreams
Has anyone applied a small piece of the 3M Clear Bra material to this area to avoid the paint chips?
I have and it works great. However I did it after getting a small chip which I touched up first. I used a piece of Cleartastic that I had, similiar to 3M.
Old Dec 20, 2005 | 08:55 PM
66dreams's Avatar
66dreams
Thanks. I'm going to try that.
