Difference between 05/06
Old Dec 31, 2005 | 09:48 AM
rick g's Avatar
rick g
Default Difference between 05/06
I'm considering a C-6 coupe 6-spd. to replace my C-5 6 spd. Conv. Exactly what are the differences between the 2005 and 2006 model years?
Old Dec 31, 2005 | 10:01 AM
not08crmanymore's Avatar
not08crmanymore
smaller steering wheel,no more reverse shutdown,beefed up rear end,xm antenna's in the side view mirrors.
Old Dec 31, 2005 | 10:04 AM
rick g's Avatar
rick g
Default reverse shutdown?
no more reverse shutdown? What is that?
nalto's Avatar
nalto
And those cheezy GM badges in front of the rear wheel wells on the 06.
Old Dec 31, 2005 | 10:05 AM
rbridges's Avatar
rbridges
hey dumbass, don't you know stickers and badges add HP?
Old Dec 31, 2005 | 10:16 AM
StanNH's Avatar
StanNH
Default And....
...from what I've read on this board, slippery steering wheels.
Old Dec 31, 2005 | 10:21 AM
Diver Dave's Avatar
Diver Dave
On the 05' manual, you have to put the car in reverse before you turn the car off and get out or the accessories power will stay on and possibly run down you battery. Don't know why GM did it, but its sometimes a pain in the A**.
Old Dec 31, 2005 | 10:26 AM
rick g's Avatar
rick g
Engine HP the same?
Old Dec 31, 2005 | 10:52 AM
Miaugi's Avatar
Miaugi
Engine HP the same?
Yes, hp & torque remains the same.
Be aware though on the ealier '05 VIN's (~3000 - 11300) there have been several "crank bolt failures", that is too say the bolt backs out, then so does the harmonic dampner/pully, then you loose power steering and spring a major oil leak to boot! It will be fixed under warranty, but not something you want to happen at all in the first place.
Also on early build cars there was a clutch issue where at high RPM's if the clutch has been known not to engage...ie: the pedal stays on the floor, also a warranty item.
Old Dec 31, 2005 | 11:41 AM
bigsipper's Avatar
bigsipper
what is meant by "beefed up rear end"? are we talking about the rear of the car because I didn't notice any difference . Or are we talking about tranny?. I have no clue.
Old Dec 31, 2005 | 11:45 AM
VET4LES's Avatar
VET4LES
Old Dec 31, 2005 | 12:54 PM
Jagcvette's Avatar
Jagcvette
Can't believe no one has mention this: No more DBS (Dead Battery Syndrome)
Old Dec 31, 2005 | 01:10 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
No more key for passenger air bag.
Old Dec 31, 2005 | 04:26 PM
Velocity Steve's Avatar
Velocity Steve
Do the badges in front of the rear wheels come off easily?
Old Dec 31, 2005 | 04:54 PM
Buy-Low's Avatar
Buy-Low
Oh Great. I am picking up a used 2005 06 with a vin in that range. Should I cancel???
Old Dec 31, 2005 | 05:19 PM
Miaugi's Avatar
Miaugi
Originally Posted by bigsipper
what is meant by "beefed up rear end"? are we talking about the rear of the car because I didn't notice any difference . Or are we talking about tranny? I have no clue.
Specifically the rear differential, the '06's have been redone to improve strength....although the '05's I've heard that failed were being abused....the new version should hold up better!
You could ask the dealer/seller if the car has already suffered a failure or and/or if the "fix" has been done? It is "guesstimated" that the problem has/will only affect ~3 - 5% of those in the range...not bad odds untill it affects your car!
So I guess it depends on the deal you are getting, the less you pay maybe the more willing you will be to "take your chances"?
Personally I would still buy an '05, but I wouldn't pay top dollar for it.
Old Dec 31, 2005 | 06:35 PM
SHOOTER 49's Avatar
SHOOTER 49
Come on guys---don't worry about crank pulley failures in the vin range. They only puke once or twice but then you can take neato pictures of them being taken away.
To Difference between 05/06
Old Dec 31, 2005 | 09:20 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Default Huh?
Oh Hell, and all this time I thought they lowered the drag coefficant.
Old Dec 31, 2005 | 09:22 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Nah, just buy an extended warranty .......................
Old Dec 31, 2005 | 09:25 PM
ProfMoriarty's Avatar
ProfMoriarty
2006 C6 changes:
A6 automatic transmission
Strengthened rear end
F55 software upgrade
2 exterior colors dropped
2 exterior colors added
New interior color
Darker "aluminum" trim
Three spoke, smaller diameter steering wheel
MN6 park in R or walk feature eliminated
Steering column lock eliminated
Nav system plays MP3s
Digital/analog On Star
HVAC chrome trim rings
Passenger seat weight sensor for airbag
Reduced ragtop bubble at speed
Hidden XM antenna
GM badges
