Does It Get Stronger
When I got my first one in October last year, I didn't think it felt all that fast to me. Then I took it to the dragstrip and turned a 12.499 at 114.9. I felt much better about the car after that. I have turned a 12.57 at 113.1 in my F55 car, and that was with only two clean runs.
Don't be deceived.
And I agree with jschindler....I have a C5 and the C6, and the C5 automatic car actually feels faster, puts you back in the seat, more G's, etc. But side by side, the C6 will pull away. It is "sneaky fast" as they say. The beauty of both of these cars is the wide power band (torque) the motor produces. It just seems to pull out hard no matter what gear you're in, or what RPM you are at.
Hang in there, put some miles on that thing and then drive it like you stole it!
Learn to enjoy and utilize the nice smooth pull that occurs across the entire rpm band of the LS2. This is one of the greatest features of this car in my opinion, and the main reason why I bought it! For street use, there is nothing better. You can be cruising along leisurely in 4th gear at 1500 rpm, then put your foot down, and without any noise or fuss you'll be doing 90 mph in a snap. The speed really sneaks up on you... that says a lot about the power delivery... there is a lot of it, and it's oh so smooth! What a car!!!!! This is how a street car SHOULD be. Thank god they are still making these big V8s!!!!!! GM, please keep the big V8 alive... please!!!
From my recent dyno plot from 2300rpms to 5900 torque is above 300. On my car, an A6 peak was 341. This means you have 88% at a minumum anywhere in this range. This is so much better than the engines of old with peaky torque curves. It just keeps pulling. And even though I miss in a way that neck snaping torque I'm really starting to like being pushed farther and father back in the seat as the speed builds. Much different feeling IMO.
) are in for a nice surprise come 7k - 8k miles or so (if at this rate you ever get there that is LOL). My LS1 Z28 from 1k miles to 8k miles almost felt like it gained 30hp with nothing else done to it.
I got on my pretty good from 40 miles on and never had a problem ... it actually dyno'd real strong at 10k miles.
Also, I agree with the others' comments on its deceptiveness of speed. I had a C5 and countless F-bodies .... first time on highway (coming from dealership after purchase
) I was at first dissapointed that it didn't feel all that fast ratcheting up through the gears ... until I notice I was going over 100 mph awfully quick .... hehehehehe
Imagine what a Z06 must be like in the low end torque department! Oh boy! But finally, there's only so much power you can put to the ground for street use. TOO much torque is actually not a good thing if all it's gonna do is spin the tires.
The gearing is a bit tall, in my opinion, with a 2.66 first gear combined with a 3.42 rear. This yeilds an overall ratio of 9.10 in first gear. In comparison, the Mustang GT has an overall ratio of 12.00 (3.38 X 3.55) and the Chrysler Crossfire has an overall ratio of 11.35 (3.60 X 3.07).
With a 3.90 rear the final drive ratio will be 10.37 in first.
Having an overall first gear ratio of 12.0:1 would be too much for an LS2... yes, you CAN overgear. I know this because I've done a lot of hands-on experimenting with transmissions, rear ends etc in various big V8 cars. One friend of mine tried a near 11.0:1 first gear overall ratio in a car with a strong 400 cube engine (set up for street use with manual tranny)... the car was nearly undrivable, had to start out in 2nd gear. We brought it back down to around 9:1 and it was good there.
I'd say my Z51's first gear is as low as it should ever be... a 2.97 first with 3.42 rear = 10.16:1 overall ratio. I personally would never recommend changing the rear gears in a Z51, the gearing is perfect. You'd only make it worse by swapping in a lower rear gear.
The base non-Z51 car... yes, 9.1:1 first overall ratio... hmmm... ok, well that's one good reason to get a Z51!
But 9.1 is still fine for the LS2.If one with a base car really needs to have more kick, I'd say maybe try a 3.73 or 3.90 rear MAX. A 4.10 would probably only hurt unless you swapped in a super big cam that made very poor low end torque compared to stock... that's when you really might NEED to upgrade gearing.
I've driven / ridden a lot of extremely fast vehicles. I am 100% happy with my C6 Z51 in bone stock form. I often cannot understand why anyone would have a strong desire to try to make it go "faster", especially after paying $50k+. The C6 gives you every bit of performance possible for the price, and it's damn powerful! Learn to appreciate what you have there. If you need to go so much faster, get a bike!
