Convertable top question
Jan 15, 2006 | 02:30 AM
OK how many of you Vert owners reset the release handle when you lower the top?
I was watching the top go down and then the cover starts lowering and contacts the top handle showing a bulge in the cover as it pushes the top down. If I unlock the top and then raise it a small amount and then relock the handle into the top the bulge goes away.
Jan 15, 2006 | 03:12 AM
St. Jude Donor '08
I've never looked at the top when it's down....
Jan 15, 2006 | 07:31 AM
I always reset the handle (to the locked position) before lowering the top. When I raise the top, I reset it to unlocked after raising the top, from inside the car, so it's one motion again: turn it to unlocked, pull it onto the windshield header, turn it to locked.
Jan 15, 2006 | 08:18 AM
Yep--I always reset the handle to the locked position. No particular reason, it just seemed like the right thing to do.
Jan 15, 2006 | 08:26 AM
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15
Quote:
I do the same.
Jan 15, 2006 | 08:46 AM
Glad you posted this, I was wondering about that. I will now close the handle. Thanks.
Jan 15, 2006 | 11:18 AM
if you are talking about the manual top you have to reset it or it will bang on the tonnoue cover when you try to close it. There is a foam piece there but it will close a lot better with the handle reset.
Jan 15, 2006 | 11:58 AM
At NCM delivery they advised me to ALWAYS reposition the handle to the locked postion when you lower the top ( power )
Jan 15, 2006 | 12:42 PM
Quote:
Thanks for the info.
Jan 15, 2006 | 12:46 PM
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Jan 15, 2006 | 04:02 PM
2020 C8 of the Year Finalist - Unmodified
I have never returned the handle to the locked position. I guess I had better start paying attention to this. Thanks.
Jan 15, 2006 | 10:03 PM
Jan 15, 2006 | 11:43 PM
Jan 16, 2006 | 01:44 PM
When I took delivery the dealer stated that this is the way it needs to be done. Doing it since day 1.
Jan 16, 2006 | 01:48 PM
Jan 16, 2006 | 02:43 PM
St. Jude Donor '06-'07
Reset. I noticed the foam dealie on the tonneau was hitting the handl;e first time I dropped the top, reset the handle ever since.
Jan 16, 2006 | 10:40 PM
Same here always reset
Quote:
Originally Posted by PeterC
I do the same.
