C6 DIC error code resetting
Old Jan 17, 2006 | 06:59 PM
AFVETTE's Avatar
AFVETTE
Default C6 DIC error code resetting
I just ordered a 06 coupe. I've owned 2 C5's since 2001. I've seen a few threads that claim I can't re-set simple error codes that will trigger a CHECK ENGINE LIGHT such as a improperly installed gas cap and that I will need to take my car to the dealer to be reset?
In the C5 all you did was turn the ignition to on, press and hold OPTIONS while at the same time pressing the FUEL button 4 times. Bingo you were in and could see all current and HISTORY (old) codes. To delete them you just pressed the RESET button.
Please tell me this isn't so?
Tom
Old Jan 17, 2006 | 07:02 PM
BigJoe's Avatar
BigJoe
In the C6 you can't even look at the codes via the DIC.
Old Jan 17, 2006 | 07:37 PM
Vette_DD's Avatar
Vette_DD
This is not your old C5.
Old Jan 17, 2006 | 07:39 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Bummer
Old Jan 17, 2006 | 07:45 PM
AFVETTE's Avatar
AFVETTE
And this is an improvement?
Are there any aftermarket code readers a consumer can buy to read the codes like they have at Auto Zone?
Tom
Old Jan 17, 2006 | 08:04 PM
Miaugi's Avatar
Miaugi
Originally Posted by AFVETTE
...Are there any aftermarket code readers a consumer can buy to read the codes like they have at Auto Zone?
Tom
Yup, as far as I know ant OBDII reader will work.
Old Jan 17, 2006 | 08:06 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Tom
It is one of the few things that is a huge step backwards. Yes, you can get an scan tool that plugs into the OBD2 port to read the codes. Too bad we can't do it for free with our dic.
Old Jan 17, 2006 | 08:10 PM
timd38's Avatar
timd38
Buy a cheap OBDII reader for $100 and do it your self.
Old Jan 17, 2006 | 08:13 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The code will clear after a certain amount of ignition cycles with the fault not detected
Old Jan 17, 2006 | 08:23 PM
talldude67's Avatar
talldude67
Best place to buy an OBDII, less than $100 is CHECKER AUTO....
Old Jan 22, 2006 | 10:45 AM
HOFFIE's Avatar
HOFFIE
Get The OBDII 3030 code reader from Walmart.Dont get the 3100.The 3030 is $69.00 & works great
Old Jan 22, 2006 | 12:04 PM
Blu06Z06's Avatar
Blu06Z06
I would be willing to bet there is a way (back door) but we just don't know it yet! Although, I think maybe they changed it because GM wants you to use Onstar (on the base models anyway) to recover your codes that way it's another reason to suscribe to them.
Old Jan 22, 2006 | 12:17 PM
Vette_DD's Avatar
Vette_DD
Originally Posted by mattandleah
Hi guys. Check out www.diydiagnostics.com I have a very good but inexpensive scan tool available for sale. Price is $54.99 plus about 4 bucks for shipping. Anyone who mentions this forum in their order will receive a $7 discount! Check it out. The tool works great. It gives you more control over viewing/clearing codes than most models. Plus, it has a nice length cord so that you don't have to spend time with your head underneath your dashboard. Works on 1996 and newer GM, Ford, Chrysler, Nissan, Toyota, Honda, and some others. No computer required. This is a self contained unit. It also comes with a handy code booklet to tell you what the codes mean.
Matt Maltarich
Are you a forum sponsor?
To C6 DIC error code resetting
