C6 rocks except.....
The other alternative is getting a silver or white car... No problem with swirls then.
I've got 4 months on the car... zero swirls... dealer prep wax is amazing, car still beads and looks mint even after several multi-hundred mile trips in rain, sleet, salt, etc. I think I washed it twice since I've had it using nothing more than typical Zip Wax car wash soap and water. Finish looks like new. Perfect.
I think the KEY is to just not wash and wax the paint so much (especially if you have a garage). Seems that the more you mess with the finish, the worse it gets over time.
My other two cars are several years old and see lots of use. I think I may have waxed them ONE time in over two years, and wash them only when they get VERY dirty... which may be every 3 or 4 months minimum. Paint looks like brand new on both cars, zero swirls, no fine scratches, etc.
I have to agree with SHOOTER 49, just drive `em! That's what they're for! As I've stated before, sometimes those who obsess over caring for their cars do more damage than good. Just DRIVE... it's really the best thing you can do for your car.
Other than that, the car rocks I don't mind washing, polishing it...I enjoy it on a nice day.
The problem is...you can't really do anything about the swirls or spider webbing that results from keeping your car clean and polished.
On lighter colors you don't notice it as much but on black it's easily spotted...particularly by the owner.
I think next time I'll get a lighter color...
Unfortunately, even if you adopt a procedure that completely eliminates putting in new swirls, the ones that are already there won't go away. Even if you make them "disappear" by using a "scratch and swirl remover" (3M One Step Cleaner Wax works very well, BTW), all this will do is fill them in. They'll stay reasonably invisible until the next time you wash the car, at which time the filler will be washed off.
heres a few shots of my 01s paint
use a PC...its almost impossible to burn the paint but i would still practice on a car i don't care to much about
I will never buy a dark colored car again though. Silver for me!
I have none on my DSOM. I use a new micro towel to wash car each time. Never use it twice. I uses new micro towels to dry it each time. If you drop one, throw it away. Never use a sponge. If you get even 1 small speck of sand in the towell or sponge, you'll now have swirls. I had a black trans am gt for 10 years and have almost no swirls using this method. When using wax you must use the same philosophy. Always use a new pad. When done throw it away. Same with towels. I've seen a couple of new vettes that already had swirls, because of the way they take care of their car. Last NO-NO. Never let the dealer wash your car or wax it. If so, you'll have swirls.
- It uses ionized water during the final rinse stage. This allows you to simply let the car air dry (preferrably in a shaded area) without getting waterspots.
- Because nothing comes in contact with the just-washed car during the drying process, there's nothing to produce scratches, swirls, or spiderwebs.
I've been using the system on my Corvette since new (picked it up in July, have washed at least 6 times since then) and it works very well. So far I have none of the dreaded scratches, swirls, or spiderwebs. In addition, I use only new or freshly-washed microfiber cloths to wash the painted areas of the car. I rinse them in clear water after washing each section.
I always start by using a plain terry towel and a pan of warm water and dishwashing soap to wash the wheels, tires, and wells. I then dump the dirty water and throw the towel into the washing machine.
Next step is to fill a clean bucket with clear, warm water for rinsing the microfiber cloth. I then wash and rinse the car one section at a time, using the Mr. Clean System and following the directions. It's very easy. I rinse the microfiber cloth in the clear rinse water after each section of the car.
After washing the car, I finish the Mr. Clean process by "painting" the entire car with ionized water, again just following the Mr. Clean instructions. It's simple and takes only 5 minutes to do the entire car.
Following this final rinse, I've had great success just pulling the car into the garage and letting it air dry overnight. Having said that, I'll admit to investing in an inexpensive electric leaf blower that I now use to blow dry most of the water off the car before pulling it inside to finish air drying. It's probably overkill, but I do it anyway.
My previous cars all developed spiderwebs early on and they drove me nuts. It didn't matter what I did - 100% cotton U.S.A.-made terry towels with the edges cut off, chamois, you name it - the result was always the same. Of course, once the spiderwebs are in the finish they're there to stay unless you machine-polish them out. With the process I'm now using, they're not showing up at all (even under flourescent light). I don't know which is more worthy of the credit, the microfiber or the Mr. Clean, but I'm sticking with both from now on.
Here's a link to the Mr. Clean web page:
Link to Mr. Clean AutoDry System
Hope this helps. Good luck.
