Vert Wind Screen
Old Feb 26, 2006 | 03:03 PM
PAVette's Avatar
PAVette
Default Vert Wind Screen
Can anyone with a Vert wind screen tell me how effective it is in reducing wind turbulance in the cockpit? Thanks.
Old Feb 26, 2006 | 03:47 PM
dashotgun's Avatar
dashotgun
This has been posted a lot I suggest the search function, however I have heard it works to some degree but it is pain to install the first time and it has to be removed and put in the trunk when you put the top up. I had thought about getting one and realized that I would not use it. More over I got my car this Dec and in Virginia we are having a mild winter. I have had the top down on some 55 degree days and the breeze blowing from behind is not to bad and you can talk normaly in the cockpit. If they had one that worked and you did not have to remove it I would buy it in a heartbeat.
Old Feb 26, 2006 | 04:37 PM
PAVette's Avatar
PAVette
Thanks...At 38 degrees today, it was a bit brisk!! I did read some old threads and got a 50/50 good/bad impression on whether it reduced turbulence, but it was real clear on reafirming what you said about it being a real pain to use. I've got what I need...and GM doesn't. Thanks, no additional responses needed.
To Vert Wind Screen
