Octane Question
Old Mar 30, 2006 | 11:14 PM
red on red's Avatar
red on red
3rd Gear
Default Octane Question
My wife has been driving my vette while her car is in the body shop after a parking lot accident. She filled the car up with 101 octane fuel thinking she was doing the right thing. Normally I use 93 octane fuel. My question is, will this harm the engine or converters or sensors in any way? I have a 05 Automatic with 10,000 miles. Thanks for any insight.
Old Mar 30, 2006 | 11:15 PM
water boy's Avatar
water boy
Where did she find 101 and how much was it?
WB
More is better.
Old Mar 30, 2006 | 11:18 PM
jabez's Avatar
jabez
I don't think one tank will do any harm. When tank is half full or or less I would mix in some 87 Octane if you are concerned.
Old Mar 30, 2006 | 11:19 PM
red on red's Avatar
red on red
3rd Gear
A Local Texaco station that she or I never use. It was $3.99 a gallon.
Old Mar 30, 2006 | 11:23 PM
jabez's Avatar
jabez
Thats a bargain. 100 octane is close to 7.00 here.
Old Mar 30, 2006 | 11:31 PM
Jagcvette's Avatar
Jagcvette
Looks like our cars weigh between 3200-3250 lbs then, not including wives, dogs, or other miscellaneous (but necessary) equipment!!
Old Mar 30, 2006 | 11:34 PM
Steve Pettus's Avatar
Steve Pettus
6th Gear
If it was unleaded, it will not hurt a thing.
Old Mar 30, 2006 | 11:42 PM
silvertc6's Avatar
silvertc6
The attached may be helpful.
File Type: doc
Old Mar 31, 2006 | 12:01 AM
sunsetZ51's Avatar
sunsetZ51
should be fine
Old Mar 31, 2006 | 12:21 AM
JohnDS's Avatar
JohnDS
That's highway robbery. In Northern CA, where everything is highway robbery, I can get it for $4.29.
It won't hurt the car to run octane too high but it could hurt your pocket book. It will only richen the fuel mixture.
John
Old Mar 31, 2006 | 01:12 AM
sanfranman's Avatar
sanfranman
Never seen a station in the state of California that sells higher then 91 octane...
Old Mar 31, 2006 | 01:22 AM
vetteship's Avatar
vetteship
Will not hurt a thing, when the gas is gone fill-up with the 91 octane and happy driving
Old Mar 31, 2006 | 03:14 AM
C6Swede's Avatar
C6Swede
Cruising
It will not hurt your engine at all. Instead it will run better since it´s less risk of setting back the ignitioncurve. I live in sweden and i run 99 octane all the time.
Old Mar 31, 2006 | 03:52 AM
DoSvdanye's Avatar
DoSvdanye
Shouldn't hurt anything as long as it has an additive package & you use it up in a reasonable time.
You can run more advance with high compression motors or supercharged motors with 100+ octane.
DoS
Old Mar 31, 2006 | 06:57 AM
Irv's Avatar
Irv
High octane burns slower (at the same CR) than 93,2,1 on down.
That's why you can run more advance with high compression motors or supercharged motors with 100+ octane.
DoS
Here we go again with the silly octane theories. Higher octane does not mean "slower burning". That is definitely not why you can use a higher compression ratio. Higher octane gasoline simply resists detonation from heat longer than lower octane gasoline. (Higher compression causes more heat in the mixture, because energy isn't lost but the volume decreases.) Other than a somewhat lower total BTU content per gallon (due to the octane enhancers) there's no other difference. It doesn't burn hotter either. Lower octane gasoline in a cylinder of the same compression ratio burns at about the same temperature. And the flame front from proper ignition (from the spark plug, and only the spark plug) moves at the same speed regardless of octane. (Really fast, but still it takes long enough that multiple spark plugs per cylinder can make a difference in high rpm motors.)
I don't know where this burn slower nonsense came from, but would you guys that don't have the slightest idea what you're talking about quit infecting others with your misconceptions?
Old Mar 31, 2006 | 07:02 AM
Larry B.'s Avatar
Larry B.
European octane rating is not the same as U.S. We use R+M/2. You guys use a single number. I don't remember which one though. European 99 is about the sam as 93 in the U.S.
Old Mar 31, 2006 | 07:11 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
actually, i think it's a pretty easy to understand why one would believe that way (higher octane burns slower).
based upon your statement;
"Higher octane gasoline simply resists detonation from heat longer than lower octane gasoline."
detonation can also be known as preignition. preignition can be known as ignition before proper time.
with that in mind, it's easy to see how some can believe that higher octane fuels burn slower, even though that's not the case.
use of 100 octane won't hurt anything, however, it may be possible that the computer will tune for the 'new' fuel then detune for the 'normal' fuel. no problem and it will only be tuning timing as it relates to knock. higher octane equals lower knock potential. i hope you didn't make you wife feel too bad, i'm sure she didn't mean any harm and thought you would have been happy that she took the time to find good fuel.
To Octane Question
Old Mar 31, 2006 | 07:18 AM
LDB's Avatar
LDB
That's true. R numbers in most gasolines are about 12 higher than M. Europe posts R numbers, which is why their gasoline appears numerically higher than ours. The difference in R and M is called sensitivity. So a typical 93 by the US method of (R+M)/2 has R=99, M=87, (R+M)/2=93, and sensitivity = 12. So your gas was almost certainly 101 R number, which would be about 2 numbers higher than 93 (R+M)/2 premium. It would be virtually impossible to get to 101 (R+M)/2 in unleaded gasoline.
And by the way, other posts are also correct. While the higher number will do no harm (assuming of course that it's unleaded), it will also do no good. Don't waste your money. Once the knock sensor senses no knocks (and this happens at 91 octane), there is zero benefit to going higher. No harm, but no good. Money to go higher than 91 is thrown down the drain.
Old Mar 31, 2006 | 08:01 AM
Ucraz-E's Avatar
Ucraz-E
Octane is not the problem, wife driving vette is.
Old Mar 31, 2006 | 09:03 AM
red on red's Avatar
red on red
3rd Gear
Thanks for all the help. I will relax now.
