I like the idea of the third barke light flasher, but from their website it looks like the sequentials flash so close together with only two lights that it's hard to tell that they aren't flashing together.
Actually your comment isn't far off. This is how it is. If your lights are NOT on like when driving in the day time, you can see the sequencing effect better than when the headlights are on. At night with the tail light filiment of the bulb burning, the sequence effect is a little less obviously BUT it can still be seen. I agree that it might be a little more obvious if there was just a bit more time between when the two lights illuminate.
The bottom line for me however is that I still like it.
This is what I heard after I ordered the kit. It is still in the unopened box in my garage. Anyone want one cheap? PM me. It also has the third brake light flasher.
Note that the webelectric turn signals are through 2005 only, unless they have changed them. My November 2005 built C6 had a different connector then what they ship for the 1997 - 2005 models. I had to return it.
Put them on my September '05 built '06 C6 the morning after returning from BG and they have been working great since. You were correct, however, in that at the time (and maybe now) they listed them for the '05 C6 but there seemed to me nothing revolutionary in tail light wiring in the '06. It has been a while but, if I remember correctly, there was an installation error in their instructions (maybe color coding of the wiring or something like that) that was apparent when tracking the wiring but that was no big deal.
Anyway, as mentioned, they seem to be working fine.
