Just picked up my Vette this weekend. Had a quick question about closing the trunk on a coupe. What's the best way to do it? At what point are you suppose to let the trunk go?
Use the built-in handle on the right side. Pull the trunk down briskly and release it from about 18" (this is not critical). A little practice and you'll get it every time...so the auto pull-down will pull it fully closed. If it doesn't latch, you can always just press down slightly over the latch and the pull-down will take over.
The amount of force necessary is substantially less if the windows are down or top off/down because there is no air pressure build-up in the car.
I dont believe you are supposed to hit it very hard on the latch. I gently push it down until it stops on the latch and then I slow push it down until the automatic solenoid pulls it down. I wish they had a C6 emblem on the hatch in order to avoid finger printing the paint. They did that with the C-5s and it worked fine.
Thanks.
Inside handle. Pull firmly down. Practice makes perfect. Let go before you slam your hand in the hatch.
Not rocket science but a learned practice.
More speed needed when all closed up as opposed to when the roof is off or the windows are down.
I just set it down gently and then push slightly until the auto close mechanism catches. Seems like it wouldn't be a good thing to slam it down onto the auto-closer...
Went to a local boat dealer bought 6" of black boat decking [black], on the back side [tan] put down a quarter, draw a circle, figure out how wide you want it to be, draw another circle, now 2 straight lines off the dia. cut out, remove sticky back put on rear glass to prevent finger prints. Can send pic if you want....save the wave
