Help with Placement
Old Apr 25, 2006 | 11:00 PM
c6nut's Avatar
c6nut
Default Help with Placement
I need my forum bothers help. I put a S/C in my car and I need tp have an A/F gauge. I am at a loss for placement. HELP, would you hide it in the cup holder tray, put it on the pilar which then would require a boost gauge. Please feel free to suggest and or comment.
Thank you,
Ted
Old Apr 26, 2006 | 12:33 AM
c6nut's Avatar
c6nut
ttt
Old Apr 26, 2006 | 01:24 AM
fastskyline's Avatar
fastskyline
put it in the pillar. it will be easy to see there and you could probably use a boost guage anyway. only downside i see is that its not exactly stealth. i dont know if that matters to you though
Old Apr 26, 2006 | 03:18 AM
Test Driver's Avatar
Test Driver
I think the easiest option would to place it in a modified pilar. You should be able to find one that doesn't require a 2nd gauge.
The cup holder is a good way to hide it if thats your goal. If I did that I would make a foldable mount within the cup holder so the gauge could be moved to an 'Up' position and down and hidden when you dont want to see it.
Personaly I wouldn't hide it. I would mount it in the dash. Above the drivers left side air vent, beside the Mode and Page buttons for controlling the DIC; depending on whats behind that area.
just my 2 odd cents
To Help with Placement
