Hatch pull down
Also, I thought I saw a thread about side marker socket replacement, but I cannot find it when I search. Can anyone help with that.
Thanks, all.
if the doors are closed i drop it from about 18" or more to close - usually just close from a foot or so then push hatch down lightly to close
(if the doors are open the hatch slams - not a good sound for me)
sounds normal to me....
You need to accelerate the hatch with a slight 'slam', from about a foot from closure. It does take practice, and seems to improve with time and miles.
So the method you see described in the posts above is it- that's how you avoid the smudges....except that I still sometimes push down a little on the hatch to get it to close.
I have to do the same ..
Git-er-done
Git-er-done
This method works for me every time.Mike
... exactly how I close mine even with the windows down.
Just a gentle slam works every time.
This approach means that you do not have to touch the hatch again.
Thanks, all.
Often leave you with it half engaged/half not engaged?
Does it have you wondering whether to slam it hard, or drop it from higher, or just press firmly with fingers?
If all of the above is true, then yes, you have the correctly set up factory latch.
It's ""normal".
You know, I love my car, and didn't really think I had pet peeves, but I guess this is actually one of them.
If it really bugs you, you can try to be sure to leave a door open when operating the latch, because a major factor is the fact that as the hatch closes, it displaces a large volume of air, and the car is so tight it does not dispell it easily. This causes the latch to decelerate right when you would expect momentum to carry the thing through to closure.
Argh.
So the idea of grabbing that partially closed hatch with a hook or finger, and completing the closure by electronically cycling it to the fully closed position is not a horrible idea. But in our cars, the execution stinks. I don't know if the latch is too weak, the action too slow, the finger too short, or what -- but it would be interesting if somebody took this on as either an undergraduate engineering problem to resolve, or a forum member was to play with mods to see what could be done through experimentation.
I'd be willing to bet that just the right mod could overcome the irregular functioning of ALL C6 hatches.
If that is the worst of our worries, we are in pretty good shape!
To assist in closing the rear compartment lid of your
coupe, use the pocket on the underside of the lid on
the passenger’s side of the vehicle. When closing the lid,
lower it until the power pull down latch feature activates
and it will close the rest of the way and latch
automatically.
