"software update"
Old Jun 2, 2006 | 10:33 AM
cmdrzero's Avatar
cmdrzero
Default "software update"
Twice now the servicing dealer has told me that i should have "new software" downloaded. of course, at my expense. i said "no." i was wondering if the "software update" is necessary or helpful to my car running well. i suppose it is some sort of either tuning software or diagnostic software. does anyone have an opinion? is my dealer/tech trying tio further rip me off? thanks in advance.
Old Jun 2, 2006 | 11:28 AM
BIGGGIE's Avatar
BIGGGIE
St. Jude Donor '05-'06-'07-'08
Well I Know you Need the Update if you want to Use The Predator..But Dont know why they would charge you...
Old Jun 2, 2006 | 11:30 AM
pmarone's Avatar
pmarone
There should be no cost involved with flashing your system to the lastest version, especially if it's under warranty.
Old Jun 2, 2006 | 11:36 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Sounds like a dealer trying to steal some money from you.
If a software upgrade is needed, that is a change mandated by GM.
Its all covered by warrenity
Old Jun 2, 2006 | 11:39 AM
anothercrisis's Avatar
anothercrisis
St. Jude Donor '06-'07-'08
There should be no charge!
I ask my dealer to check when I go in for anything at all. They just have to hook up the diagnostic machine and it will tell them if all the software is updated. There is supposedly diagnostic as well as other software updates available from time to time. HOWEVER, these same guys did not know about the software update for the early 05 nav radios that would enable them to play MP3's. I did that one myself.
anothercrisis
Old Jun 2, 2006 | 02:57 PM
rwpatte's Avatar
rwpatte
Software upgrades don't make it better. Sometimes it makes it worse.
Try your bios on your home computer, and then hold your breath when you reboot.
Old Jun 2, 2006 | 03:09 PM
SicMSP - Daniel's Avatar
0SicMSP - Daniel
Former Vendor
My check engine light came on about 3 months ago, when I took it to the dealer they said that all it was was a software update needed... who knew that our cars have software timeframes...
Old Jun 2, 2006 | 05:52 PM
Hoonose's Avatar
Hoonose
I have not heard that before, maybe I've missed something.
But if not, it's sounds like a smooth parry by your dealer, just hoping that the error won't return.
Old Jun 2, 2006 | 07:25 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
As per GM,the dealer should perform a software update to your vehicle only when the update is to correct a specific complaint documented on your repair order.If the printout of the update that is required to be attatched to the repair order does not address the concern on the repair order,GM will not pay the dealer for the procedure.For obvious reasons,GM doesnt want the dealers performing updates to every vehicle that comes in the shop.
You should never have to pay for a software update if your vehicle is under warranty
Old Jun 2, 2006 | 09:50 PM
Jbal's Avatar
Jbal
What software update are you addressing-just curious.
Old Jun 2, 2006 | 10:26 PM
Jimbeaux's Avatar
Jimbeaux
Old Jun 2, 2006 | 10:30 PM
purple heart's Avatar
purple heart
Default What about...
How does On-Star fall into all this then????????? That little deal cost me $548.00 that included a 3-yr subscription.
Old Jun 2, 2006 | 10:33 PM
CoolBlueC6's Avatar
CoolBlueC6
My car has not been reflashed and my Predator, thus far, has worked flawlessly to upload and down load tunes and monitor the car. James from runningwiththedevil.com did mention that I may want to have it reflashed though.
Old Jun 3, 2006 | 02:57 AM
BIGGGIE's Avatar
BIGGGIE
Your Car is Prob Newer then Mine and his.. Mine is a Early 05 March 05..I think Its got to do with That...
Old Jun 3, 2006 | 08:23 AM
SickRick's Avatar
SickRick
Sad part is, these updates take all of 5 minutes to perform.
1 - Hook up Tech2 to car to read current ECU.
2 - Hook up Tech2 to PC to check and download updates into Tech2
3 - Hook ip Tech2 to car and flash.
OK, 10 minutes TOPS...
Rick
To "software update"
