I am curious about what I should set my tire pressure at. In the morning when I get started up, it is at 30 psi, but in the afternoon when the temp heats up they are at 35 and 36 psi. Is this good or should I adjust.
Raptor
The manufacturer KNOWS THIS IS GOING TO HAPPEN. They have determined the proper "cold PSI" that will give the best contact patch and performance, and life of the tire. If you follow 30 "cold PSI" You are fine.
That's normal. I usually set mine so that it'll be about 30 PSI at the coolest part of the day (which is usually first thing in the morning). That means putting in a little in the fall and often taking out a bit in the spring.
Expect about 1 PSI per 10 degrees F ambient temp, another 1 or 2 PSI for direct sunlight, and 2 or 3 PSI for normal driving temperatures.
As JNJ said cold PSI of 30-31 is where you want to be. Ambient temperatures can have a noticeable effect on tire pressures even when they are at rest. So even "cold tires" can see a fluctation of several PSI on a car at rest if the temperatures swing 50 degrees in a day.
Set tire psi to what the door jamb/owners manual says to when cold. In this case 30 front and back. As to the definition of cold. Driven less than one mile or stationary for at least three hours.
I know this reply will get me "flamed", but I've always believed in going a bit on the high side for tire pressures. Yes, the door tag on my '05/Z51 says 30 lbs, but I use 32 lbs cold. Once on the road & warmed up, they'll all run 35/36 which seems to be ideal.
Lots of tire shops do this also ride will get a bit more bumpy and gas mileage may go up slightly.
The Tire Guy
I do not intend to flame here but why does this question get asked so often? Don't they have drivers ed anymore? It is on the door jamb on all the cars I have owned.
I have been in the auto repair/tire business for over 20 years and I can tell you beyond a shadow of a doubt...people do not read the owner's manual or look at the door jamb. They expect the repair shop/dealer to keep it up for them. Your typical Corvette owner is at the other end of the spectrum. Not only do you read it but you could help them write the next one!
They are mandatory now federal law cars come equipped with them so I would expect alot of these tire places even Costco should get a handle on not damaging the sensors.
I would miss the tire sensors if I did not have them. I have decided to put sensors in my drag radials also. Now I need to find a bartec tool cheap.
I know it is easy just to check the air pressure. But I come from an aviation background and I love gauges and info. I am going to love playing with the nav stuff, even though the primary place I drive in 10 miles to the track and back on a back road.
Then you have to love those old 63 and up Jaguar XKE's.
