I recently had paint work done, and my body shop told me he had to mix in some white to get a perfect match. He says GM mixes the black with white and yellow at the factory. Doesn't make much sense, but my paint matches perfectly and my body shop is pretty highly regarded, so don't see any reason why he would be wrong.
He did show me my old hood with some straight (unmixed) GM black paint sprayed on to compare, and to my unprofessional eye it didn't match, as it was darker than the factory job.
The best place to get your paint code is off the installed equipment label on the glove box door. A color formulation may change during the MY...the 41U won't change, but the actual mixing code can change (probably not for black). The paint code will be below all the equipment codes, along with the interior color code (193 = ebony)...be careful to get the right code.
The paint code will be a three digit number preceded by a letter and followed by a letter...I believe the following letter is "U". You should also see BCCC (base coat/clear coat) near the paint code.
From: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
Does it vary from black car to black car? If it does, shouldn't the Dealership have taken this down before they painted my roof?
I usually knowwhere to look for paint codes, as im a certp ainter /body man..... BUT as i know and some people know, the body codes change from place to place, spare tire, trunk, glove box, console, etc...... and my car isnt black, its for a forum member who i may be painting for them, and ifigured it was easier to ask yall then to explain where to look for it. - Roger
Maybe not in the case of black. It's particularly important for metallic colors that have run for a number of years. In the case of Magnetic Red, there were about a dozen different formulations over the years.
If your dealer has a large body shop, they may also mix their own paint; if they have the car or a color sample, they can tinker with basic black until they get it right. For small shops and individuals doing their own work, it's better to be prepared with the paint code right off the car. If you go down armed only with the merchandising paint code (41U), they will probably want to know your model year, VIN number, etc. so they can verify the exact formula.
