Does anyone shift 1st-3rd-5th??
Old Jun 28, 2006 | 02:57 PM
sofgl's Avatar
sofgl
Default Does anyone shift 1st-3rd-5th??
I disconnested the CAGS (thanks for dodging the gas guzzler tax! But what a peice of sh-- to have on a drivable car!) I have tried out shifting, mostly in town where the traffic allows it, from 1st to 3rd then to 5th gear. I rev high enough so that it will shift smoothly and let the RPMs drop slightly so there is not a drag. Anyone else doing this and are there any downsides to this? Seems like a better idea than 1st to 4th!!I have a Z51 transmission so the gearing in the first 3 gears is lower as well.
Thanks in advance for your comments!
Old Jun 28, 2006 | 03:00 PM
AFVETTE's Avatar
AFVETTE
Frequently, the LS2 has so much torque that 1-3-5 is easy and probably saves some fuel and wear and tear. But then again that's the beauty of the M6 (as long as you have a CAGS By-Pass). You can pick most any gear and go. I don't want or need a computer getting in the way.
Tom
Old Jun 28, 2006 | 03:02 PM
C64BOB's Avatar
C64BOB
Sometimes 1-3-5, sometimes 2-4-6. Z51 also.
Old Jun 28, 2006 | 03:48 PM
TRR's Avatar
TRR
Sometimes I go from 1st to 2nd to 6th
TRR
Old Jun 28, 2006 | 05:30 PM
CMEPASU's Avatar
CMEPASU
Just cruising I go 1st, 4th, 6th
Old Jun 28, 2006 | 06:24 PM
sofgl's Avatar
sofgl
I am more worried about the motor transfering enough oil throughout the motor at lower RPMs doing my shifting method. I never let it get below 1000 rpm. Am I worrying about nothing??
Any more comments?
Old Jun 28, 2006 | 07:17 PM
C6Harley's Avatar
C6Harley
I dont see any problems with the cags or a need for the eliminator. If I want to shift from 1 to 2 instead of 1 to four just put your foot down more than 1/4 or so of the way, not a big deal.
Old Jun 28, 2006 | 07:20 PM
CBB's Avatar
CBB
Sometimes 1-3-5.
Old Jun 28, 2006 | 07:26 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Although the torque is certainly available to do so.....I am not a skip-shifter by choice. Even though I'm rarely if ever affected by the 1st to 4th skip-shift, I will soon be installing the GAGS defeat. I also appreciate not having to pay a gas-guzzler tax but otherwise, GAGS can be quite annoying.
Krause's Avatar
Krause
FWIW, I shifted 1, 3, 5 in my C5 all the time and never had a problem with it. Seemed like a great way to save a bit of gas and have a bit more torque at my disposal than CAGS allowed.
Old Jun 28, 2006 | 08:09 PM
johnodrake's Avatar
johnodrake
Moderator
Old Jun 28, 2006 | 08:23 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
1st to 3rd is my standard shifting pattern when just loping around town.
CAGS is not usually an issue however.
Old Jun 29, 2006 | 08:42 PM
AraiGP4's Avatar
AraiGP4
Short shifting and skipping gears, IMHO, detracts from the overall pleasure of driving a high performance sports car. Why bother? If I couldn't afford the gas, I would have selected a Prius. Just drive it! Leave the economy runs for the EPA.
Old Jun 30, 2006 | 02:45 AM
2LT-Z51's Avatar
2LT-Z51
1st to 3rd to 5th when crusin.....
1st, 2nd, 3rd, 4th, 5th or 6th is way more fun..... but the speed comes up very quickly... love to hear the engine
above shifting at 4000rpm or so....
Old Jun 30, 2006 | 03:24 AM
VetterGetIt's Avatar
VetterGetIt
It's a neat idea, experimentation is good, altho I like to feel all my gears, especially 1-4.
Old Jun 30, 2006 | 03:34 AM
leimomi's Avatar
leimomi
Cruise-In VII Veteran
When I'm not in a hurry I skip gears all the time. I've also found that if I shift very slowly (maybe moving through the gate helps) the CAGS seems to time out and I can shift into second at low RPM's. Anyone else notice this?
Old Jun 30, 2006 | 03:51 AM
lexaudio's Avatar
lexaudio
Yep, that is what happens.
What 1 second and your standard 1 to 4 becomes 1 to 2nd.
LEX
To Does anyone shift 1st-3rd-5th??
Old Jun 30, 2006 | 11:20 AM
6 speed Sid's Avatar
6 speed Sid
I never skip any gears, shifting is too much fun.
Old Jun 30, 2006 | 03:30 PM
oslinrm's Avatar
oslinrm
From: In the mountains of VA surrounded by roads that any of you would be envious of!
Usually shift through all gears...also have listened to all the "must have CAGS eliminator" arguments...CAGS has never been a problem for me, just rev it up a little and goes directly into 2nd every time.
Old Jun 30, 2006 | 03:48 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
St. Jude Donor '06
1-3-5 some times
