split window conversion? any interest?
Old Jul 26, 2006 | 09:44 AM
ProfMoriarty's Avatar
ProfMoriarty
Originally Posted by Hippiehead025
well i happen to have metal fab skills, aswell as welding skills
Wouldn't composite fab and adhesive skills be more in line with the task?
Old Jul 26, 2006 | 01:42 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
This would be my preference on a plastic car.
Old Jul 26, 2006 | 02:16 PM
teazr1's Avatar
teazr1
I'd suggest you do some drawings or photochopping and submit them and then see what people think. I don't think I'd personally be a fan of having a split window, but there might be some people who would.
Old Jul 26, 2006 | 02:21 PM
Ira 81's Avatar
Ira 81
maybe someone will do a photoshop of the idea.
Old Jul 26, 2006 | 05:50 PM
RBYCC's Avatar
RBYCC
well if there isnt an interest, im not gonna do it, haha. IM not gonna waste time for nothing, lol. But what iwas actually thinking was to take an actual 63 split window section and glass it in to replace the rear window. could get $$$$ but it'd be original and noone has one done.
Could be problematic as the scale and contour is different on the 63.
Why not mock up with some Avery or 3M adhesive backed vinyl.
This way you can get the correct proportions for the C6.
Worst case is that you peel off some vinyl that cost you under $50.00.
If you like it, pattern it, and consider fabricating out of ABS which is easy to work and is used on car exteriors. Probably don't want to go more then 1/8" thick. ABS can be attached to the existing glass area with a VHB tape.
Old Jul 27, 2006 | 06:52 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Well, I played around in photoshop with the idea. Here are a couple of quick renditions with some slight variation on the proportions of the rear window opening.
The first one is more faithful to the original:
The second is allowing for additional rear visibility.
Paul
Old Jul 27, 2006 | 07:05 AM
cmb13's Avatar
cmb13
Nice work.
Not sure I'd want it, though.
Old Jul 27, 2006 | 07:41 AM
su8pack1's Avatar
su8pack1
Not for me, but still would like to see one.
Old Jul 27, 2006 | 02:03 PM
Major Smoke's Avatar
Major Smoke
If Corvettes still had T-tops it might look ok, but I think the angle of the rear glass on a C6 is too great to pull off the '63 look by itself.
Old Jul 27, 2006 | 03:13 PM
RedHotC6's Avatar
RedHotC6
If any I like the first pic. Not sure that is the Mod I want first, I give it a 5 out of 10
