C6 Skip Shift Eliminator
Old Dec 17, 2006 | 05:53 PM
  #61
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Originally Posted by qs vette
I spent about an hour today getting my car up and finding what I believe is the connector to the CAG solenoid (it was the only connector I could find in the area described). There are 3 connections, one in, one out and the connector seperates in the middle. When I took it apart, it did not appear the the connections were same. The "eliminator" has two pins, the connection had 4.
Do you have a picture of the solenoid so can make sure I am working on the right thing? I stopped and put it back together. If not, I will have to return mine.
I have a C5, but the plug is the same.....I do not have any pictures but let me see what I can come up with. Worse comes to worse, I will jack up my car and snap a quick picture...Hang in there, I will get you something that will clear it up for you.
Jim
Old Dec 17, 2006 | 07:13 PM
  #62
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
If the tranny is similar to the T56 in the camaro, then this might help.
The reverse solenoid is #2 and the skip shift is the next connector forward.
If not, I apologize and I'll wait until I get the Helms on the C6. Until that time, here is a tranny case from a 2004 Y body. The skip shift solenoid is identified in the callout list. May that will help.
Elmer
Old Dec 17, 2006 | 07:39 PM
  #63
qs vette's Avatar
qs vette
Jim
Thank you for the help. I am a visual person. A picture is worth a thousand words. I have hit that 1-4 shift point too many times.
Thanks.
Old Dec 17, 2006 | 09:24 PM
  #64
JCtx's Avatar
JCtx
Hey GSVette, remember the camaro has the tranny in front, and the Vette in the rear; NOT the same.
Having said that, it should be close, and with enough light, fairly obvious. There's an orange label, plus a mounting 'hole' to secure the connector; that's where a tie-wrap goes.
Old Dec 17, 2006 | 10:02 PM
  #65
eboggs_jkvl
Moderator emeritus
Whereever you put the transmission, it still looks the same. The skip shift is in front of the reverse lockout solenoid in the similar area of the "rectangle" on top of the tranny in front of the shifter.
Elmer
Old Dec 20, 2006 | 02:26 PM
  #66
southerncarparts
Supporting Vendor
Thanks.
Ok, so are you ok? Or do you need me to get under my car and snap a picture for you?
Let me know, and if not I will do it today...
Thanks,
jim
Old Dec 21, 2006 | 08:07 PM
  #67
qs vette's Avatar
qs vette
I am still not sure on the location. I thought I might just go to a Chevy dealer and get a parts diagram of a transmission. All the talk about transmissions didn't help. I just need to see what I am looking for.
Old Dec 25, 2006 | 09:48 PM
  #68
southerncarparts
Supporting Vendor
Here is the plug you want to remove.....
Hope this helps....This is a C5 but should look the same...
Let me know if this helps or not....
Jim
Old Dec 26, 2006 | 03:25 PM
  #69
qs vette's Avatar
qs vette
Default Found it!!!
Just wanted to thank you for your patience and time. I will definitely look for products from you in the future.
It really does only take 5 minutes to install !!!!
Thanks again.
Old Dec 26, 2006 | 03:35 PM
  #70
TopNotch's Avatar
TopNotch
I did mine on Sunday Morning, my wire was actually labeled "Skip Shift." took me 5min using rhino ramps.
Old Dec 28, 2006 | 08:34 AM
  #71
southerncarparts
Supporting Vendor
Thanks again.
My pleasure.....glad I could help out.
Skip Shifts are in stock for whoever else wants one!!!
Thanks,
Jim Vose
Old Jan 28, 2007 | 07:15 PM
  #72
jmagilto's Avatar
jmagilto
Default Skip Shift - Take Two...
Just ordered mine. I had installed a different kit - from another vendor - back in May when I first got the C6.
It was slightly cheaper - and somewhat different in design. The wire fell out of the resistor housing after only a couple of months, causing the car to show the check engine light for Skip Shift Solenoid.
Your design - from the pictures at least - looks somewhat better. Thanks! and I look forward to receiving the item.
jer
Old Jan 28, 2007 | 08:09 PM
  #73
bdog01's Avatar
bdog01
Just ordered one from your website. You can send along with the window valet that i ordered earlier today.
Old Mar 1, 2007 | 11:14 AM
  #74
SheLovesBlue's Avatar
SheLovesBlue
Thanks - Just ordered one
Old Mar 19, 2007 | 05:12 PM
  #75
andyk5's Avatar
andyk5
The main reason why 1-4 skip shift is there is gas savings, is it actual gas savings? not really since anybody who drives a manual corvette uses first gear more than 1300-1500 rpms. So whats the real reason behind all this?
I belive GM used this 1-4 shift thing to beat EPA. When these guys do theri testing for official window sticker MPG figures and gass guzzler tax, I belive they have strict rules on how they drive the test vehicles. I am not sure what they are but they are probably, if its a car, and manual and this many cylinders, then rev engine to thi rpm then shift and rev to this rpm, reach this speed etc.... so Gm found out the paramaters and never gave EPA the chance to use the second gear of their car, since they had to rev it to lets say 2200 rpm to be able to beat the skip shift but rule book said to test you shift before 2200 rpm. As I said earlier i dont know the actual numbers, rules and rpm's but this is the most logical explanation to me.
Old Mar 20, 2007 | 01:37 PM
  #76
SanDiegoBert's Avatar
SanDiegoBert
Just ordered. I don't even have the car yet!
Old Mar 21, 2007 | 09:14 AM
  #77
southerncarparts
Supporting Vendor
Thanks, you won't be disappointed. Enjoy that new ride of yours.
To C6 Skip Shift Eliminator
Old Apr 9, 2007 | 11:02 AM
  #78
Jeff's Vert's Avatar
Jeff's Vert
Just ordered today. Looking forward to normal shifting again.
:auto
Old Apr 9, 2007 | 11:52 AM
  #79
deereman's Avatar
deereman
Default 2007 Z06
Jim, just ordered a Skip Shift Eliminator. Sorry to be so ignorant but I assume the 2007 Z06 has the M12 6 speed and that your skip shift eliminator will work on my car. I've searched the forum and haven't found that clearly stated. Thanks, Dennis
Old Apr 9, 2007 | 06:50 PM
  #80
southerncarparts
Supporting Vendor
It will....
Thanks,
Jim
