article on nitrogen inflation
Old Oct 2, 2006 | 10:31 AM
cfl70's Avatar
cfl70
Veteran: Marine Corps
Default article on nitrogen inflation
here's a interesting article on nitrogen inflation (at least hondas point of view) i think you fellas may like.
http://www.in.honda.com/Rjanisis/pubs/SN/A060900.PDF
hope the link works.if not copy and paste
Old Oct 2, 2006 | 10:41 AM
Miaugi's Avatar
Miaugi
Interesting reading....but I'll keep using nitrogen in my tires.
Old Oct 2, 2006 | 10:56 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
you're already using 75%
Old Oct 2, 2006 | 10:57 AM
427Z's Avatar
427Z
just curious. where do you get nitrogen? price?
Old Oct 2, 2006 | 11:13 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Interesting read and it confirms my personal opinion about using nitrogen in your tires....it's more of a 'fad' for passenger cars and the benefits are negligible at best.
Old Oct 3, 2006 | 03:21 PM
Low Rider's Avatar
Low Rider
The only benifit to us Vette guys is that loss of air during storage should be reduced......
Old Oct 3, 2006 | 03:27 PM
NORTY's Avatar
NORTY
...or the water vapor freezing (Michigan!) and corroding the TPS system...
Old Nov 21, 2006 | 09:42 PM
moevette's Avatar
moevette
The air you breath is 78% nitrogen....people make a big deal out of nitrogen inflation and it is just a marketing thing...sounds good but really air is mostly nitrogen
Old Nov 22, 2006 | 12:51 AM
glennhl's Avatar
glennhl
Exactly how I feel!
Wayne, December 1st, I'm going out late to Firebird.
Old Nov 22, 2006 | 09:56 AM
vetdude's Avatar
vetdude
If this were true, why do the pro's that run the Bonneville Salt Flats for the land speed record, e.g. Greg Breedlove in the Shell Spirit of America, as well as commericial aircraft, use nitrogen exclusively in their tires? (saw it on Speed TV). If it reduces the constant fluctuation in air pressure due to the ambient temperature, I'm all for it.
Old Nov 22, 2006 | 11:37 AM
shopdog's Avatar
shopdog
PV=nRT it isn't just a good idea, its the law. What it tells us is that all gases behave the same way with respect to temperature (as long as the temperature is above the liquefaction point), IE pressure change is directly proportional to temperature change. Nitrogen is no different than ordinary air in this respect.
Land speed record tires and heavy commercial and military aircraft tires are operated at very high pressure (roughly 300 PSI). In the event of a crash and fire, the release of high pressure air would make the fire worse. Since nitrogen doesn't support combustion (at ordinary temperatures), it is a slight safety improvement to run pure nitrogen in high pressure tires.
The one real advantage to running pure nitrogen is that the purification process removes the water vapor that's present in ordinary air. Water's liquefaction point is in the ordinary temperature range, so tires containing moisture won't exactly follow the ideal gas law. But we can achieve the same effect with ordinary air by using a desiccant filter (used for spray painting) on the output of our home compressors.
Old Nov 22, 2006 | 02:08 PM
adale's Avatar
adale
Just my two cents worth.........Nitrogen changes volume depending on temp so little is why most ppl use it in their tires. In highspeed applications it is critical that the tire stays the same diameter with the same pressure if possible and I believe it becomes non-linear at a certain point, so the tire could easily burst or at least come off the rims. A lot of the real high speed cars run either solid wheels with no tires or solid rubber tires super balanced.
At legal highway speeds our tires only gain a pound or two if they are inflated correctly and have no problems. They will only loss a couple of pounds if the temp gets real cold. It is interesting that tires gain heat more quickly if they are grossly under or over inflated.
I guess it is each to their own, but around here I have seen it advertised for upto $7 per tire for the nitrogen fill. I bought a small "E" cylinder of nitrogen last year for $32, which would fill about 100 tires at 32 PSI.
Maybe I should open my own business...............
Old Nov 22, 2006 | 02:12 PM
Michrider's Avatar
Michrider
That article is 100% on the money. Everything else is cow pie material.
Pressure sensors have been around many years in caddies. Those old farts aren't dumb enough to fall for the nitrogen fad, and their sensors have been just fine.
I've got a nit wit friend that manages a tire store that pushes that crap. What does he here many times a week. My tires leak and your salesman told me nitrogen doesn't leak.
It's tire store snake oil. Period. Yes, maybe if your name is Craig Breedlove or Jeff Gordon you may have a use for it. But Joe Bloe in his street car - Air, Air is what you need.
Repeat after me:
I will stop falling for these marketing scams
Old Nov 22, 2006 | 02:27 PM
06.Z51.MontRed.Vert's Avatar
06.Z51.MontRed.Vert
From: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
No way man, Nitrogen gave me an extra 50HP, I swear it really did...
Woops, that was helium, yep helium in the tires reduces the weight of the car, best mod ever!!!
Old Nov 22, 2006 | 02:58 PM
Vette_DD's Avatar
Vette_DD
Why would I want to put something in the tires of my C6 that very few, if any, service stations carry? Where I trade, they have plenty of air and it's free.
Old Nov 22, 2006 | 03:14 PM
DJ-LO's Avatar
DJ-LO
The Goodyear station's here have it for $2.50 a tire for the life of the car and for as many times as you even change/replace your tires. $10 for lifetime ain't too bad...
Old Nov 22, 2006 | 03:19 PM
C8-Vette's Avatar
C8-Vette
But it's the 18 percent Oxygen that is killing us and possible the tires. Can't live without it but it's slowing killing us. Could Michael Jackson be right?
To article on nitrogen inflation
Old Nov 22, 2006 | 03:44 PM
Levitating_Llama's Avatar
Levitating_Llama
The human body is still 80% water even after a black mamba injects a half ounce of venom into your leg but the effect is quite real.
Old Nov 22, 2006 | 03:53 PM
Curtis A. Franz's Avatar
Curtis A. Franz
It doesn't reduce constant fluctuation relative to tire or ambient temperature! Nitrogen comes as close to an ideal gas as any other diatomic gas. As such they all respond to temperature increase with a pressure increase.
Old Nov 22, 2006 | 04:18 PM
moevette's Avatar
moevette
with air in your tires the pressure changes 1-2 psi when warmer, is it worth paying 60$ or more for nitrogen that will not do this??? i dont understand why that would matter much but that is about the only true statement about nitrogen inflation...it not leaking out as fast dosent really matter because its not like you can drive on it for an extra 50 miles at regular speed like a run flat or something. But if you want the constant tire pressure i guess this is for you everything else is bull
