Nothing works
Old Nov 3, 2006 | 06:40 PM
Deftly's Avatar
Deftly
Default Nothing works
Well none of this works: mirror, seats, windows, telescoping steering wheel, door open, rear hatch. Had to open the door and hatch manually. I figure I have major fob failure. Spare fob doesn't work either.
Anyone else encounter this? If so, how did you fix it? I guess the car has to go back to the shop for a reprogram.
Old Nov 3, 2006 | 06:44 PM
rwpatte's Avatar
rwpatte
Read the manual on reprogramming. That might save you a trip.
Old Nov 3, 2006 | 06:53 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Dead battery? Does the DIC display anything when you try to start the car? Unlikely both fobs will fail or have low batteries at the same time. Did you try plugging a fob into the transmitter pocket in the glovebox and try starting the car? Can the car start? If not, jump it and then check if these things operate with the car running. Check fuses.
Old Nov 3, 2006 | 07:13 PM
2K7Z51's Avatar
2K7Z51
dead bat in car?
Old Nov 3, 2006 | 07:14 PM
torquetube's Avatar
torquetube
Does it start?
Old Nov 3, 2006 | 07:15 PM
Deftly's Avatar
Deftly
No dead battery and car starts. I'll check the manual.
Old Nov 3, 2006 | 07:16 PM
timd38's Avatar
timd38
Originally Posted by 2K7Z51
dead bat in car?
It would help if your profile told us what year and what trans you had.
Old Nov 3, 2006 | 07:17 PM
Hoonose's Avatar
Hoonose
DBS if '05 MN6, otherwise dead battery for any other reason.
You need to charge it real good, and make sure that nothing was left on. It should then start and everything should work.
It needs to be checked by the dealer, battery and charging system.
If it's '05 MN6 it needs the new BCM reflash for DBS.
Old Nov 3, 2006 | 07:26 PM
timd38's Avatar
timd38
Also if it is an early 06 with an auto trans or On-Star or both, you need a flash also.
Old Nov 3, 2006 | 09:40 PM
Deftly's Avatar
Deftly
It is an '06 auto trans built in Nov 05.
Old Nov 3, 2006 | 09:56 PM
weathermaker's Avatar
weathermaker
Could the battery be dead if it started?I don't think so.Did you have to use a jump to start it?
Old Nov 4, 2006 | 05:20 AM
timd38's Avatar
timd38
There was a bug in the ECM that left a module on in the trans. If they flash the ECM that may fix it assuming that is the issue.
Old Nov 4, 2006 | 06:27 AM
Deftly's Avatar
Deftly
Who performs the flash - the dealer?
Old Nov 4, 2006 | 11:00 AM
Deftly's Avatar
Deftly
Just back from the dealer. To give you feedback, here is what happened. Turns out a wire under the driver's seat was chaffing on a seat bolt. Eventually it blew the #33 60 amp fuse. That fuse powers everything I mentioned when I began this thread. Wire repared and rerouted and back on the road.
Old Nov 4, 2006 | 11:26 AM
weathermaker
Glad that they found the problem.
To Nothing works
