I have a nail in the tread portion of the tread run flat. Still holding pressure and most of the tire life is still there.
Question, should I have the nail taken out and is the tire fixable or should I just keep the nail in until the tire loses pressure and then get it fixed or replaced?
Take the car to a run-flat certified Goodyear store. Take your little Goodyear warranty pamphlet with you. Your tires are covered from road hazards (it sounds like yours are nearly new). They will probably be able to patch the tire at no cost to you. If the tire cannot be repaired, it will be replaced at no charge.
Take it to a GoodYear dealer or GoodYear-authorized tire shop that can handle runflats & get it repaired. Take the GoodYear tire warranty pamphlet that you got with the car with you. If you've had the car a year or less AND have worn less than 2/32" of tread off the tires, the repair will be free.
If, for some reason, the tire's not repairable, it will be replaced by GoodYear for free, if under the stipulations stated above. If older than that, GoodYear will prorate the price of a new tire.
Had exactly the same thing happen to me last month. Drove the 40 miles home and then next morning took it to GY for a free repair. Absolutely no hassels.
Had the same thing happen to me and got it fixed. If you drive fast like me, you don't want to chance the tire messing up somehow.......then you won't have to worry about it.
From: Life ain't no dress rehearsal, are you gonna wait to get your toys til AFTER you have a heart attack?
I don't believe that treadwear comes into play when the tire is repairable unless there is less than 2/32 tread LEFT. Then it is considered worn out and they probably won't repair it. I may be mistaken though. Going down to the garage to read the warranty again.
Yes, I think you are mistaken. In the paragraph headed by "Free Tire Replacement", note the sentence near the end of that paragraph that says, "Repairable punctures will also be repaired at no charge during this period." The paragraph itself was talking about "during the first 2/32" treadwear or 12 months from date of purchase, whichever occurs first."
Had a screw in my front tire (05 VR vert). Took it to Goodyear. They pulled it out and tire was fine. No loss of air. Have it removed before it works its way through the rubber.
I inquired at www.goodyear.com for retailers, looking for one with the 'Runflat Repair' logo.
Queried Tulsa and Oklahoma City, Oklahoma.
No dealer certified to be runflat repair was returned.
I know Oklahoma is kinda the sticks, but this sucks.
What to do, what to do, if I get a flat?
I've run into the same problem, sure doesn't give me confidence of finding a certified repair facility when on a trip. That's why I carry a small compressor and repair kit....in case Goodyear doesn't come through with a location.
There are places in OK that handle runflats. I found a couple listed in OK City and didn' look any further. Perhaps you're not reading the symbol for runflats correctly. Run it again and you will find them in OK...
