2006 A6 Transimssion Issue
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Originally Posted by dark_phantom
I thought LAPD had those APS twin turbos set to 9 lbs so that the transmissions were not pushed. Now you're noticing that even at 8 lbs the torque is too much.
Hopefully, RPM will come up with an upgrade soon. Thanks for the information.
Actually, we have set the A4 and A6 tranny vehicles we have done with the APS kits at no MORE than 6 psi which was more than enough power to remain safe, yet with plenty of power. I drove all of them and they all put down at least 500 rwhp! They all turned out great!
We felt that 9 psi was too much for the automatics to handle unless they had built up trans work, a good TC and maybe even 3.42 gears so that they can really handle and make the most of the the added boost.
We didn't want to experiment and make our customers guinea pigs by putting that much boost through stock automatic transmissions.
Shawn
Shawn,
Thanks for the clarification, I got confused and thought it was set to 9. Makes sense and has enough power, it makes me feel better.
But I'm still hoping that RPM can get us an upgraded transmission. It won't be long before I get an APS kit myself.
Originally Posted by cthusker
Some people were saying the A6 should have no problem being dropped into a Z06 so why doesn’t GM offer it. I wonder if that's just wishful thinking. Perhaps GM doesn't want to warranty a ZO6 with the A6 tranny installed. It’s one thing to roll the dice on 1 car with lots of HP and the A6. It’s quite another however to build several thousand of them and have to warranty them
It will be interesting to hear what the problem was…
I too will be interested to here the outcome.
I took the car to RPM transmissions in Indiana today. Met with Rodney and Todd; toured the shop and had alot of good conversation. They are both very professional and I know I am leaving my car in good hands. They will go over the transmission and differential; they will upgrade the items needed to handle the power. Rodney said they will take pictures and document the upgrades when they finish. So I will update this thread when we have more information.
Rev Matching
I have a new 2007 A6. The dealer promoted the idea that the car matches revs on downshifts. Now that I have the car, I find that the best it does is drag the engine up on the torque converter. I also have an Infiniti M45 and a BWM 750Li and they both actually blip the throttle to match, so I was expecting the same with the new Vette.
Is my car operating correctly?
#33
#36
Originally Posted by bobamick
Now you know why GM doesn't offer the A6 on the ZO6.
Bob Amick
Bob Amick
#37
I have been wondering about max hp power and torque with the A6, I think you are at edge and feeling the pain, but no gain. Its like diff blowing out on a LFelter in one of the mag article with DR's. Hopefully, more people will start reporting more of these problems at the limit of HP and TQ. Good luck with better results, I think there has been talk about 580 ft lbs of torque max on the A6.
#39
