From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Originally Posted by AU N EGL
I can understand. I change my oil ever two weekends on the track or about every 500 miles. Each session is 25-40 min and oil temps for those sessions are 250-265* and the driving is constant 3000 to redline, 50 to 140 mph, 3 to 5 times evey 2:15 secs or so
When I change the oil it goes in a nice translucent golden brown and when It comes out it is black sludge.
I reset the DIC to 100%. After one weekend on the track or about 250 miles the DIC is down to 70%. After two weekends on the ( about 500 miles) track about the DIC reads 30%. I change the oil and send oil samples to two differnt labs for annalysis.
What I also do is when all the oil has drained out, I pour an extra quart though the block and for about 1/2 of that quart it is still dark sludge, then turns golden brown like fresh oil.
Both labs say my oil change is about right. Three weekeds would be too much.
I use M1 15-W50.
You are the best. Now let me ask another question if I may..IS it 5-w50 or 15-w50?
Mobil 1 Synthetic, SAE 5W-30, API SM, ILSAC GF-4, energy conserving, GM Standard GM4718M, GM Part No. 12345610
and change the engine oil and filter as per the maintenance section, the LS2 will never need a flush.
No no, Once I pour in the new oil, , I check the new oil with the dip stick, and see that it is still dirty..
It is essentially impossible to drain all the old oil out when you do an oil change. There will always be a film of oil left in the engine even if you drop the pan and wipe it out with a rag. Less than a tablespoon of old oil will make your new oil look "dirty". Ignore it, it means nothing.
As mentioned before, you've got the wrong oil in it. Get that 15,000 mile stuff out of there and use the silver cap regular Mobil 1.
If you want cleaner looking oil, change it more often. On all my vettes and F-bodies I've changed it at 3,000 miles and years later after an oil change it will still look like new oil. At 3K it starts to look a little dark. Now that's a clean engine.
But there are those who will argue to the death not to change the oil that often. But you seemed concerned on how to get clean looking oil, and the answer is on your next car change it more often.
On the flush questions - hell no. The last thing you want to do is stir up all the gunk and redistribute it around the enginge.
I use M1 15-W50.
If I were you I'd give Redline a try and I bet you'd find your analysis results would be better, and you could probably extend it to three or even four weekends of racing without a problem. You could probably even step down in viscosity to 10w40, without losing any protection at all. M1 15w50 thins out to a 40wt quite easily already anyways. Redline is much more shear stable and perfect for hard driving.
If I used Redline I might be able to extend it. I would prefer a lower then 15-w50, more like a 5-w50 or a 10-w40.
It has been a while since I look at the shear ratings of oils. I do not rember the Redline 40 wt shear ratings.
Redline 10w40 has an HTHS number of 4.7, which is actually better than the 4.6 of Mobil 1 15w50! So you'd get the best of both worlds, a better protecting oil that is a thinner viscosity for better HP. You might even run cooler oil temps too, because the oil is so much thinner and isn't creating as much of a drag on the motor.
The two big problems with Redline are cost and availability though. But if you can find it easily and don't mind the extra cost, it's definitely worth the money if you're doing a lot of racing. For street use it's still good, but pretty much overkill when there are cheaper oils that will do a good job too.
Avilbilty is not to bad down here. My track buddy runs Redline 40wt in his ZR1. Goes 4 weekends I think then changes.
The "black sludge" is caused by heat and/or oxidation.
St. Jude Donor '08
I drive her hard and change the oil around 1,800 to 2,500.
St. Jude Donor '08
WILL THERE BE ADVERSE EFFECTS IF i USE THE EXTENDED 15,000 MOBILE OIL? I was just wondering cause I just $62.00 on trhe oil change yesterday..Any opinions out there?
1. GM COULD, but probably wouldn't, deny warranty coverage if your engine or cat converter went bad.
2. Over time, the extra additives in the Mobil1 EP oil may damage catalytic converters, that's supposed to be the main reason GM doesn't approve it.
3. I'm pretty picky about stuff like this, but i'd just leave the EP oil in there until the next change at normal interval.
St. Jude Donor '08
Phew , now I can go to sleep at night..hehehe ,,hey thanks bud..
Damn, you guys are a little conservative. What the hell, my sticker on my car was $58000 on my car. I change the oil every 3000 miles regardless of how I drive, and it cost $60 each time. I could care less when my damn car payment is $1150 a month! I could care less if the oil is still good or not. My oil is just turning a darkish brown when I change it, and when I have been beating on the car a bit, it will be dark brown, but I just like it when my oil looks nice and clean whenever I check it. Hell I flush all my fluids in the car every 15000 miles, why not?
St. Jude Donor '08
