Finding 93 Octane
Old Dec 4, 2006 | 03:56 PM
rwebcon's Avatar
rwebcon
Default Finding 93 Octane
How would one go about finding stations that have 93 octane fule? I live in the phoenix area and have not seen one!
By the way can you see any difference between 91 and 93?
Old Dec 4, 2006 | 04:00 PM
rwebcon's Avatar
rwebcon
Default By The way - for the record
The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting.
The compression ratio of your engine determines the octane rating of the gas you must use in the car. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight -- that is what makes the engine "high performance." The disadvantage is that the gasoline for your engine costs more.
Old Dec 4, 2006 | 04:06 PM
NORTY's Avatar
NORTY
If you require 93,you may have to "make" it.
They look the same to me!
Old Dec 4, 2006 | 04:09 PM
NORTY's Avatar
NORTY
Close. Octane is a measurement of a fuel's BURN SPEED. The rest of your post is accurate,however.
Old Dec 4, 2006 | 04:21 PM
AU N EGL's Avatar
AU N EGL
AZ maybe one of the states that limits to 91 Octane.
Old Dec 4, 2006 | 04:22 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
Come to Indiana it's at every station here.
Old Dec 4, 2006 | 04:25 PM
orca1946's Avatar
orca1946
The computer in your c ar will run on 87 if you want . Theis will result in less HP ,but it will run fine on 87 -103
Old Dec 4, 2006 | 04:29 PM
mikeyc6's Avatar
mikeyc6
All 93 here in Maryland. I've never even seen 91. That brings up a question. I've always wondered what's with the few states that only offer 91? I can't imagine that they ship "special" fuel only to those states and they ship "better" fuel to everyone else. Seems like some sort of scam, but I can't figure out quite what! Do they just take 93 octane and pee in it?
Mike
Old Dec 4, 2006 | 04:39 PM
Vette5905's Avatar
Vette5905
I have had a similar experience where I live. The highest octane I can find locally is 90. On a few occasions I have seen a 91 marking, however I tend to believe it is mismarked because a dozen other (same brand) stations within a mile are so will be marked 90. Anyone know what to make of this? When I leave my area and especially when I go north and east the octane goes up. We "grow" gasoline around here, why do we send all the good stuff up to the northeast?
Old Dec 4, 2006 | 04:54 PM
wsharp24's Avatar
wsharp24
We have 91 AND 93 here in Georgia...South Carolina does too.
Old Dec 4, 2006 | 05:15 PM
OregonC6's Avatar
OregonC6
I lived through the demise of leaded premium and what a disaster that was for performance cars of the time!
My prediction is that octane will continue to drop. More gasoline can be made from the same amount of oil at a lower octane. International and market pressures will drive octane numbers even lower.
GM is marketing a car, the Z06, for which the recommended fuel is not even available in half the country. lol
At least in the old days the manufacturers stopped making cars that needed leaded premium before it went away...and it went away FAST.
The engines of the C6 and Z06 IMO have compression ratios that are too high even with computer knock sensors and the ability to adjust on the fly.
It will not get better only worse. Use lower octane in these engines and you get lower hp and knock.
The comp ratio of vette engines needs to drop to the 8.5 to 9.5 range and soon. Perhaps with the LS3 this will finally happen. They cannot, IMO, sustain comp ratios in the 11 range.
just my opinions.
someday 91 octane is going to seem like very high performance juice.
Old Dec 4, 2006 | 06:10 PM
SHOOTER 49's Avatar
SHOOTER 49
Get 93 here but I'm always skeptical .
Old Dec 4, 2006 | 06:33 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
We have 87,89,91,92,93,94,100,111 all within a 10 mile radius from me, at most local gas stations. Oh, btw I live In Long Island, NY..
Old Dec 4, 2006 | 06:36 PM
IwntmyZTV's Avatar
IwntmyZTV
Mike
I think everything arrives the same at 87, then an additive is added to boost octane in the higher octane "mid" & "premium" fuels.
Old Dec 4, 2006 | 06:39 PM
IwntmyZTV's Avatar
IwntmyZTV
91 is our limit... Same here in Cali- if you want to try, most gas stations offer octane boost. Put a bottle in before fill up. It makes a difference at WOT but not much just cruising.
Old Dec 4, 2006 | 06:53 PM
Duke/Earl's Avatar
Duke/Earl
In Cali the truck delivers two octanes; 87 & 91. They are mixed by the station pump 50/50 to create the midrange 89 octane. Pretty sure Phoenix is the same as its gasoline is pipelined from Cali.
Old Dec 4, 2006 | 06:54 PM
70454's Avatar
70454
Sunoco has discontinued the Ultra 94 and now call the 93 "Ultra". Some scattered Sunoco stations still offer 100+ "race fuel".
To Finding 93 Octane
Old Dec 4, 2006 | 07:09 PM
azhawk's Avatar
azhawk
Navigator
[QUOTE=rwebcon]How would one go about finding stations that have 93 octane fule? I live in the phoenix area and have not seen one!
There is an Amoco station on the SW corner of Lincoln Drive and Scottsdale Road that sells higher octane (94+). If my memory serves me correctly, it is a full service station (they pump it for you) and pretty much charge you out the a$$. As far as I know, that is the only place to get over 91 octane in town however, so you'll have to pay up.
Old Dec 4, 2006 | 08:14 PM
Patman's Avatar
Patman
We've still got 94 octane Sunoco here in Ontario, although I've heard rumors that they might be doing away with it and going to 91 octane like the rest of the stations here. With my dyno tune, I need every last bit of the 94 octane, it already pings a tiny bit at part throttle with 94!
Old Dec 4, 2006 | 08:45 PM
PAVette's Avatar
PAVette
I can get 91, 92, & 93....can't really tell any significant difference.
