Oil consumption between changes...
Old Dec 8, 2006 | 01:47 AM
shopdog's Avatar
shopdog
38,000 miles now. I change when the DIC says, between 6,000 and 8,000 miles, and so far zero oil consumption. (Well, certainly not zero, but too small to notice any drop on a dipstick.) I'd consider a quart in 2800 miles excessive, though GM doesn't. But a quart low isn't going to hurt the engine unless you're routinely pulling some serious G and uncovering the oil pickup.
Old Dec 8, 2006 | 04:06 AM
tdelena's Avatar
tdelena
St. Jude Donor '12, '14-'15, '17, '20
I think I added an extra quart between the first and 2nd oil changes(1800-6800 miles). I drive the car really hard(hit the rev limiter in 4th the other day), but I am not sure that is it. I have a feeling it is choking some oil at start up.
Old Dec 8, 2006 | 07:32 AM
shortski's Avatar
shortski
Just over 10K, just did the second oil change before putting it up for the winter, ZERO oil consumption between changes.
Old Dec 8, 2006 | 11:08 AM
rapidrikC6's Avatar
rapidrikC6
4,300 miles including track time at Road America. One oil change at 2,400 miles. No oil consumption.
Old Dec 8, 2006 | 11:17 AM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Originally Posted by catbert
Mine uses 0 oil between changes...drags, trips, city driving, makes no difference.
Old Dec 8, 2006 | 12:25 PM
fapdds's Avatar
fapdds
Default oil hungery
My 05 vert Z51 consumes oil like my wife goes thru my money!! i have about 2700 miles, and had one oil change at 1200 miles. Since i got the car i've personally added over three mobile 1 to keep the oil level at the third hole. What is going on? Anyone else with this agressive oil consumption?
Old Dec 8, 2006 | 08:49 PM
spdnvet's Avatar
spdnvet
4,500 and zero oil consumption
Old Dec 9, 2006 | 04:34 AM
magredcpe's Avatar
magredcpe
nada
Old Dec 9, 2006 | 08:46 AM
weathermaker's Avatar
weathermaker
How many miles on the car? Do you drive the car hard? Are you using the correct oil? If low milage,and normal driving it should not use oil. 14000 miles and never added oil between changes,
Old Dec 9, 2006 | 09:10 AM
DEV-06C6's Avatar
DEV-06C6
Default O oil @ 3900 miles
Changed the first time @ 500 miles. Seemed like gasket sealer came out with the oil. Used nothing so far. 2006 C6 Manual trans.
Old Dec 9, 2006 | 10:29 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Originally Posted by billsee
Part of the '01 model year used rings with reduced tension against the wall. Some of those rings didn't seat and had some oil consumption. Mine was one. GM said "we'll do a teardown and replace the rings or we'll give you a 100K warrantee on the engine". I took the warrantee. At 25,000 miles the rings suddenly seated and the oil consumption went to zero.
Zero consumption on two C6s.
Lucky guy. My '01 was a qt/4k miles after breakin, was up to a qt/3k miles by the time I traded it at 68k.
Our C6 seems to be burning about 1 qt per 12k miles.
Old Dec 10, 2006 | 08:22 AM
BlackZ51Vett's Avatar
BlackZ51Vett
14.5K on mine. No oil comsumption between oil changes. First change at 3K and every 3K after that.
Old Dec 10, 2006 | 03:11 PM
  #33
6speedC6's Avatar
6speedC6
For first change to second used 1/2 qt. BUT from then 5K to 8200miles used two quarts.
Going next week for an oil change. Swiching to Amsoil.
Old Dec 10, 2006 | 08:11 PM
  #34
cthusker's Avatar
cthusker
6000 miles 2 oil changes and nothing required between changes....
Old Dec 17, 2006 | 12:56 AM
  #35
conv6spdC6's Avatar
conv6spdC6
Cruising
My 05 C6 loses about 1 quart every 1500-2000 miles. PITA, and not much can be done unless you want a GM tech ripping the engine open and redoing rings, which is what service told me needed to be done to solve the problem after running 2 consumptions tests.
