C6 weight reduction?
if the C6 shaved 150 pounds wouldn't that equate to atleast .01 to 0.2 tenths of a second off of 0-60 times?
Would it really cost much more?
Also search on the 100s of posts moaning that the Vette doesn't have every bell and whistle that the {enter any foreign car here} has.
For everyone like you there are 20-30 folks that could care less that their must-have air conditioned seats, or whatever, add weight to the car.
I guess it wouldn't be cost effective for GM to offer it seeing as they have the Z06 and they sell like hotcakes.
I never thought about that, but it would be a great idea. Basically the same and the C5 hardtop. I'm curious how much an option like that would cost. Remember that the C5 hardtop actually cost less than a base C5, even though it included 2 significant options: Z51 and the then-more-expensive 6 speed transmission. Although it didn't have as much exotic materials as the C6Z does.
Three Easy Ways to Lighten the Coupe and Convertible
http://forums.corvetteforum.com/show...e&forum_id=100
1) Aluminum Frame - 136 pounds lighter than steel frame. If stiffeners
are added, the increase will be no more than 10kg=22pounds.
2) Magnesium Crossmembers - The rear crossmember is likely to be worth nearly
the same mass savings as the front (5.5 kg = 12.1 lbs).
http://search.nrel.gov/query.html?co...tyle=eere&ws=0
3) Polycarbonate Rear Hatch - Use the new Exatec 900 system. The current
one in the coupe and Z06 weighs 23.08 pounds. There is 11 pounds of high Cg
mass to shed.
Carbon fiber and titanium are way too expensive for much use in the
base models - maybe titanium valve retainers. Magnesium isn't in the
same price class as titanium and CF.
So, without major aggrevation, the C6 diet could be worth:
114 + 12*2 + 11 = 149 pounds
I'd be happy with the frame and the front crossmember.
