why park in reverse
Old Dec 21, 2006 | 08:35 PM
jim besh's Avatar
jim besh
Default why park in reverse
my dealer told me if i did not park the car in reverse,it would kill the batt.,is that true
Old Dec 21, 2006 | 08:36 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
If you are driving a 2005 Manual transmission yes it is. The car has several computer systems that are triggered to shutdown via the car being shifted into reverse and turned off. This feature has been the source of much controversy and contributed to a failure mode referred to as DBS (Dead battery syndrome), do a search on this one. It was eliminated in the 2006 model year and the shift to reverse is no longer required. The shift to reverse is used as in the manual it is recommended that the car be parked in reverse as it is the gear with the most compression and best opportunity to keep the car from rolling.
Paul
Old Dec 21, 2006 | 08:44 PM
Firedog's Avatar
Firedog
The good news is, you don't HAVE to leave it in reverse; once the shutdown procedure is complete, you can put it in neutral without risking a dead battery...
Old Dec 21, 2006 | 08:47 PM
saplumr's Avatar
saplumr
Yeah, but ya gotta listen to the horn beeping.
Old Dec 21, 2006 | 11:36 PM
C6-Stingray's Avatar
C6-Stingray
Yeah I wish there was away to turn off all the annoying horns in the car
Old Dec 21, 2006 | 11:39 PM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
If you would finish filling out your profile we could provide an exact answer. The answer differs depending on what year you have.
Old Dec 22, 2006 | 12:04 AM
Vette_DD's Avatar
Vette_DD
Too many have posted here lately when they're having problems and they don't give enough information about what model year or set of options they have.
If you're not going to fill out your profile, including a little info. about your car, at least include the information when you make your first post about a problem or situation.
Old Dec 22, 2006 | 08:56 AM
Gburg's Avatar
Gburg
Luckly it does not do it all of the time. Chiming happily away, as if the ignition key is in the ignition, upon opening the door to get out of another vehicle. But I am getting in the Vette, w/ the fob in my pants pocket. Stupid car!! Sometimes the horn honks twice, when I open the door to get in, trying to leave w/o attracting too much undue attention (w/ the Vette is this an oxymoron?) I am glad that my C6 does not do this all of the time, but it is still annoying.
Gburg
Old Feb 17, 2007 | 08:07 PM
johnnyhulk's Avatar
johnnyhulk
if you happen to encounter any battery issues try shifting to reverse before shutting down!
Old Feb 17, 2007 | 08:14 PM
Vette_DD's Avatar
Vette_DD
OP has edited his profile to indicate he has a 2007 model. Should be no problem NOT putting it in reverse.
Your dealer is probably one who would have not put an 05 in reverse the first 3 or 4 times they had it in for service.
Old Feb 17, 2007 | 08:16 PM
Sven's Avatar
Sven
St. Jude Donor '08-'09
Paul
Old Feb 17, 2007 | 08:17 PM
Vette_DD's Avatar
Vette_DD
Gburg
Either:
1. Post specific information, and more of it, about what you're doing when the car dings or the horn blows ; or
2. Read your manual some more.
We can probably help if you can't find it in the manual and will post the details here. Be aware that other objects in the same pocket with the fob can block the signal and make the car temporarily "think" there's no fob. Also cell phones and cell phone chargers in the cockpit sometimes cause problems, especially the chargers.
Old Feb 17, 2007 | 08:20 PM
johnodrake's Avatar
johnodrake
Moderator
I leave my car in reverse primarily because of the habit of backing into the garage and leaving it there.
Old Feb 17, 2007 | 09:44 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by JimTN
Either:
That, is no lie !
Old Feb 18, 2007 | 03:28 AM
calemasters's Avatar
calemasters
No, not with your 2007.
Old Feb 18, 2007 | 04:13 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Old Feb 18, 2007 | 12:20 PM
overrev64's Avatar
overrev64
What do you mean by this. If you shut the car down correctly, the only reason the horn should beep is if you have left the fob in the car when exiting. I have an '05, and have never experienced any problems what so ever when shutting off the car using the proper procedure. No chimes, no horns, and not ONE dead battery.
To why park in reverse
Old Feb 18, 2007 | 12:33 PM
300mph's Avatar
300mph
I have an 07 and I can shut down in any gear with no battery problems and no warning chimes.
Old Feb 18, 2007 | 01:53 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Find a new dealership. You drive a 2007 so obviously your dealer isn't paying attention or doesn't have a clue (or both). As you now know, the need to 'park in reverse' only applies to the 2005 6-speed manual shift C6.
Old Feb 18, 2007 | 02:17 PM
Hoonose's Avatar
Hoonose
This is a description of DBS initiating.
If you properly shut down in reverse, then go to neutral before exiting the car, and the horn still blows, check your DIC for the 'shift to reverse' warning.
Your initial reverse shut down did not register with the BCM, and DBS would occur in about 48 hours if you don't drive the car sooner.
In fact I have 'saved' my car many times from DBS by doing just that. My car will show the warning about once every 6-9th shutdown.
