New wheels
Old Jan 12, 2007 | 11:12 PM
mdwsr2003's Avatar
mdwsr2003
From: Metro Atlanta (by way of L.A.) Ga (Army Strong Retired)
Default New wheels
I ordered some Chrome Z06 Replicas in stock C6 tire sizes, will be here next week, Im getting them installed at my local chevy dealer where I bought the car, oops I mean Vette/Machine, Is there anything specific I need to know when getting them mounted? or should the chevy dealer already know it all. Do they need to be balanced, Also approx how much should I expect to pay
Old Jan 12, 2007 | 11:16 PM
crabby2much's Avatar
crabby2much
Go to a shop that has a Hunter GSP Road Force Balancer. Best balancer there is. The wheels are decent quality, but they will need some weight. Watch out for a wheel that's out of round as well. Has been known to be an issue with these wheels.
Old Jan 12, 2007 | 11:22 PM
Mellow- Yellow's Avatar
Mellow- Yellow
Cruise-In VII Veteran
It cost me $165.00 to have my Z06 replica wheels installed. They did a great job mounting and balancing and I had them put nitrogen in the tires. I am sure I paid extra for that but I think it is worth the extra cost.
Old Jan 12, 2007 | 11:28 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Why?
Old Jan 12, 2007 | 11:33 PM
Mellow- Yellow
Why did I have nitrogen put in the tires or why did it cost extra.
Old Jan 13, 2007 | 01:41 AM
ilkhan's Avatar
ilkhan
Im sure he meant why nitrogen.
Because IIRC nitrogen molecules are larger decreasing the normal pressure loss, and because the molecules expand less with heat making the pressures more stable over time and use.
Old Jan 13, 2007 | 02:05 AM
2LT-Z51's Avatar
2LT-Z51
in hawaii i would take it to a tire guy not the car dealer.....
$50 a tire avg here
not to many here have the equipment to change a run flat.....
goodyear in kaneohe and kailua (only ones)
to find road force dealers
Old Jan 13, 2007 | 10:41 AM
Mellow- Yellow
Thanks for the reply. Nitrogen also lessens the breakdown of the rubber caused by regular air and most importantly to me, nitrogen has very little water in it so it does not corrode your wheels.
Old Jan 13, 2007 | 11:22 AM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
Two things to be aware of are to make sure they put the pressure sensors in the same location on the car. Also make sure they replace the O-ring on the inside of the sensor.
Old Jan 15, 2007 | 06:16 PM
Anes's Avatar
Anes
...and make sure and say no wheel weights on the outer lip.
Old Jan 15, 2007 | 06:21 PM
timd38's Avatar
timd38
Pull a vacuum to about -28 and you will get all the moisture out, just like you do for an air conditioner or you don't get the full benefit of nitrogen.
I use plain old air with a drier on the compressor line.
$100 is about the going rate in Detroit area for a remount and balance.
Old Jan 15, 2007 | 06:30 PM
orca1946's Avatar
orca1946
Most dealers don't have the ability to change vette tires . find a recommended local place.
Old Jan 15, 2007 | 08:46 PM
KevinDavid's Avatar
KevinDavid
Originally Posted by ben dover
Why?
Nitogen is great in cold climates. When it gets to -30 the tires don't lose pressure.
Old Jan 15, 2007 | 09:32 PM
torch2000vert's Avatar
torch2000vert
Take it from a man who knows......
Old Jan 15, 2007 | 09:40 PM
glennhl's Avatar
glennhl
Actually air has a molecular weight of 28.9 and Nitrogen is just 28. So Air molecules weigh more. So, why do people WASTE their money filling their tires with Nitrogen? Because they can. Actually the only real reason to use Nitrogen is that it's dry. If you get any water vapor in your compressed air, then the pressure can vary more versus the temperature. If you use dry compressed air, then you really can't improve on that.
Old Jan 16, 2007 | 07:24 PM
Tom_Slick's Avatar
Tom_Slick
I was thinking about doing a set of these myself... But I also remember someone posting pics in here with what looked like stock C6 wheels but in 19' and 20' vs 18' and 19' sizes!
Old Jan 25, 2007 | 05:19 PM
johnnyhulk's Avatar
johnnyhulk
tom slick, where did you get that cool looking bra? can i get that custom made for my DSOM vert.
To New wheels
Old Jan 25, 2007 | 08:52 PM
mdwsr2003's Avatar
mdwsr2003
$50 a tire avg here
you were right on target with the price to get my wheeels mounted, and I got it done right down the street from my dealer on Nimitz, see ya on the road. Hooahhh Army Strong
Old Jan 26, 2007 | 10:58 AM
2LT-Z51's Avatar
2LT-Z51
got any pics?? bet it looks like this...
Old Jan 26, 2007 | 10:04 PM
mdwsr2003's Avatar
mdwsr2003
Lets see Army Musuem right next to the Outrigger Hotel Waikiki
