I am getting tired of dbs
Location: Objects in your mirror are losing , Long Island, NY
1 Post
St. Jude Donor '08
Got hit tonight, all dressed up ready to take the vette to a party. Hit the push start, went back 5 feet in reverse on driveway and then just like that it died.. Cold a$$ weather doesn't help (25 mile per hour winds and 25 degrees...burrrrr). It's saturday night and I got stuck. I am dying to find out why it doesn't start. If it's the battery it's the 3rd one from GM due too DBS. I tried to start it with heavy duty portable starter to no availe......Grrrrrrr...A basball bat to the C6 would make the pain go away at this moment..Sorry but I had to vent...
1 Post
St. Jude Donor '08
...Even more Grrrrrrrr...
CF Senior Member
Do be aware if you've had any custom tune the re-flash will overwrite it.
DBS will generally not let you start the car at all, as the battery is already stone dead.
The car is left or properly shut down in reverse?
First of all has the charging system been checked and the battery load tested?
I assume nothing was left on, and the car is driven enough to keep the battery up.
I assume there are no aftermarket items that could drain the battery while the car sits, such as lojack or radar detector.
The new BCM reflash can't hurt, but most likely something else is going on with your car or battery.
Can you give us details on your other dead battery episodes?
DSB has been reported anywhere from 25-35% of forum '05 MN6 owners. So you're right about the majority.
The BCM is not affected by a tune. That's the ECM, as I recall.
I used to believe this also. That is until it happened to me(twice in a year). Haven't been in for the dealer re flash. I had read earlier reports of this not fixing anything?
And nothing to suggest that it doesn't work.
Yet.
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
When my 05 z51 MZ6 had a dead battery syndrome episode it wouldnt even open the doors. When you tried to start it the gauges went dead. This was after a 2 day sit.
After a New battery and BCM reflash and it has sat for 10 straight days and started right up. No voltage loss on the battery if you tested with a Voltmeter. I even opened the doors and closed them a few times in that 10 days.
Sounds like you may have something else going on.
Still, I would have the BCM Reflash. Have them check the Alternator output too.
If you have any add on electronics I would take them off to troubleshoot.
Ipod thing is Bad and I've heard Lojack is Bad and causes Dead Batteries.
I want the Lojack so I may get it and see if it really causes DBS after the reflash. If it does then I will remove it.
Good Luck, it will work out in the end.
Most likley NOT DBS.
Thank you. Everyone wants to blame the battery. The battery is the result not the cause. That being said, DBS does have a big impact on battery life, because it is not designed to take that abuse. if you want to keep running it dead and recharging it, get an Optima Yellow Top.
