Driving a C6 in Snow-What is your experience?
I've gone through 2 Chicago winters with my 2005 MN6 coupe daily driver, and am starting the third one. I purchased a set of comp grey wheels on Ebay for $600 and mounted four Blizzaks (225/45-18 front and 255/40-19 rear). Never had any problems.
Of course, the snows don't hook up, even in the dry, so you have to go easy off the line. One going, go-stop-turn is ok. Of course, you have to adjust for less traction than OE tires in the summer, but it is a good driving lesson.
I say go for it. The looks on other people's faces as you motor along in your "summer" car are priceless.
Autoweek had an article about the differences in FWD, RWD, and AWD in snow. Link to full article.
Biggest myth about Rear-drive is that it is useless in snow. The No. 1 way to improve your car's traction and handling is to install a good set of winter rubber. Learning to drive properly in winter conditions is also at the top of the list. And since most modern rear-drive vehicles feature traction and/or stability control, you'll amaze your passengers with how easily your car handles Old Man Winter.
I drove mine to work last Monday in snow and ice. It was no worse then my 97 Cobra was in the snow.
THe following applies if there is less then 3" of snow on the road (this is the most I have driven in so far). If you go slow you are fine. The only problem I had was with with two areas where the road has a slight incline. In these areas the rear started to walk out to the left a little bit. The only thing to do is let off the gas (a little bit) and keep moving up the incline even if you are a little sideways . However, if the incline is too steep or you let off the gas too much you are NOT going anywhere.
With that being said, if you have another driving option you should use it.
Location: Deerfield, Illinois Turn On, Turn In, Track Out
I have had my Z51 MN6 since 6/05, and I did notice tire slip with OEM supercar tires. I bought a gently used set of wheels from a fellow forum member and the Goodyear All-Season EMTs, with tire pressure sensors from Fred Beans. It is expected that you will have to buy new tires at some point, so instead of wearing out one set and replacing it, I use 2 sets with different purposes and get more use out of the car. I noticed a significant improvement in traction, as the summer tire compound is just too brittle for good traction in cold weather. I have driven in the snow and it's not bad, either as long as you drive with a little common sense. The active handling and traction control is priceless in the winter.
Here's to seat heaters!
Update: Chicago got hit with about 3 inches of snow which was a surprise for me today, so I had the vette and not my snow car. I have all-season runflats which are better than the summer Z51 tires in the cold, but they are not true snow tires. The car was drivable being very careful on flat stretches, but I got caught on a tollway offramp. Even going slow and driving carefully, the incline caused the car to slide (slowly and painfully) towards the inside shoulder until I thought I would lose it. Once the offramp cleared of traffic, I was able to make it out, with the ABS and traction control going off constantly. It was not fun. If I had had the car in competitve driving mode, it may have allowed a little more wheelspin and yaw to allow me to get out easier without the computer being convinced I was going to be in a 2 mph crash. Driving in snow is not new to me, but I will check the forecast from now on and drive the beater in the white stuff.
I too drove about 60 miles today in Chicago snowstorm. 4 Blizzaks. Absolutely no problems, except for other drivers who forgot how to drive in snow since last winter.
Hey you better hurry up and take your car into the dealer. Your outside temp gauge looks like it's missing a few "lines" and it put a dash in front of it too!!! Also do you think 64 is warm??? LOL
Good morning everyone. Thanks for all your input regarding driving in snow. In ref. to ice, "no car cuts it". I am leaving Mar. 2nd. but based on most comments, I will be watching the weather patterns and if necessary may leave a little early, if it looks like we may get hit with something substantial. Nothing wrong with a snow-bird spending a few more days in the warmth of the south. Regards Dusty
