sounds like the shaft adjustment is off... well it's not really an adjustment.... but the shaft has a slot for the bolt/coupler to go..if it comes a little loose it will still work....
it has a little movment and it sounds like it is at one end of the slot...
[QUOTE=y2kredauto;1558869789]After getting my recall flywheel/clutch replacement, it seems my shifter is pretty far to the right inside the cutout for it in the center console cover. For example, first gear looks dead center left-to-right. If shifting into reverse and pushing a little extra hard, it seems I can make contact with the right-edge of the console. Does anyone else notice this? I was thinking about pulling off the console, loosening the shifter bolts, and seeing if there's enough play to move the shifter slightly to the left. But if there's no play, I don't want to go to the trouble.[/QUOTE
I have exactly the same problem. Had my torque tube / clutch / rear main seal serviced. Now it is hart to get into reverse or 6th.
