gas cap not open
Old Feb 17, 2007 | 06:31 PM
wratran's Avatar
wratran
Default gas cap not open
My gas cap does not pop out when the button is pushed...several times. Is there a quick fix or adjustment for this?
Old Feb 17, 2007 | 07:15 PM
Vette_DD's Avatar
Vette_DD
Push the button with one hand while you're jiggling the edge of the gas door with the other hand. Mine started doing that about 2 weeks ago.
Old Feb 17, 2007 | 07:37 PM
John's '07's Avatar
John's '07
From: I don't deserve this car, but I have arthritis and I don't deserve that either. Bay Point, FL
St. Jude Donor '06-'07
On the vert there's an emergency gas cap release on the inside side of the trunk on the left. Since you don't have your profile filled out I don't know if you have a coupe or vert.
Old Feb 17, 2007 | 07:58 PM
Vette_DD's Avatar
Vette_DD
The coupe also has a gas DOOR release, but I don't think that'll help with the problem. The door just won't open because of ice in the vicinity of the door hinge.
Some here are confusing the word "cap" with the word "door." I think it's the gas "DOOR" that's the problem, not the gas cap. The emergency release cables have nothing to do with the gas cap.
Old Feb 17, 2007 | 11:07 PM
Radical05's Avatar
Radical05
Default What he said
Get it out and then get it replaced.
Old Feb 17, 2007 | 11:29 PM
Vette_DD's Avatar
Vette_DD
Sorry, I was just assuming it was the cold weather, since mine's only been doing that since the 20-degree weather got here.
Old Feb 17, 2007 | 11:44 PM
shopdog's Avatar
shopdog
Good assumption. The panels shrink in the cold, making the fit to the door latch tighter. When it is really cold, I have to help the door open. But when the weather is warm, it pops open freely. You can adjust the solenoid release, but I guarantee you'll have to adjust it back when the weather warms up or the door will come flying open on its own while you drive.
Old Feb 18, 2007 | 12:54 AM
Wayne O's Avatar
Wayne O
CF Senior Member
My 'panel' also shrinks in the cold.....but when the weather is warm, it pops open freely. Thank God I live where it's warm most all the time.
Old Feb 18, 2007 | 02:05 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Surgery ? Oh that sounds painful ...................
Old Feb 18, 2007 | 03:07 AM
calemasters's Avatar
calemasters
Yes. I had to replace the fuel door release actuator and cable assembly.
The original part corroded and the internal spring broke.
Old Feb 18, 2007 | 04:14 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Old Feb 18, 2007 | 08:39 AM
05dwived's Avatar
05dwived
Mine seems to work fine in the heated garage!!! Have not put gas in it since last October and with a foot of snow out there it will be in for a while. Just rub it in Wayne while I have to wait for warm weather.
Old Feb 18, 2007 | 10:44 AM
Wingrider's Avatar
Wingrider
Had the same problem. I looked closely at the door fit, and noticed that there are some "stickems'" or whatever you call them, that were out of alignment. I pushed them straight again and the problem ended.
Old Feb 18, 2007 | 11:01 AM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
Me too, last two times I filled up. I push the button and then have to pull the door open with my fingernail.
Wingrider, could you try to describe your fix in more detail, please? A pic perhaps? thanks.
Old Feb 18, 2007 | 12:52 PM
UBETRUN's Avatar
UBETRUN
Make sure the plastic leash is wrapped on the left (front) side of the gas cap. If the leash presses on the filler door, it won't open properly.
Old Feb 18, 2007 | 03:00 PM
User 020720's Avatar
User 020720
I've noticed this on my car so I push the leash out of the way.
To gas cap not open
