Okay Guy's be easy on me as I'm new to a Manual Tranny.
I have a 2007 Vette and am trying to understand what is the best way to use the Reverse gear when backing out of a garage? I've been told you can use the Clutch to manage the speed in which you exit the garage. I initial would let out the clutch all the way, but the speed of reverse seemed to fast, and applying the brake seemed to cause the car to want to stall.
So, what technique do you use?
Ride the clutch just slightly until you get the hang of it
You need to work the clutch and gas pedal. Gentle on the gas, slip the clutch as necessary to back out nice and easy. Does take a bit of practice with the 'vette clutch. My 2006's clutch tends to engage pretty fast as you let the pedal up.
So do you ever let the clutch out completely? Is there any concern of causing damage to the clutch by using it to control the speed of the car in reverse when backing out of the garage?
I think the best technique might depend on your driveway - uphill or down, straight or curved. If its downhill you can probably just let out enough clutch to get it moving then coast - that's mostly what I do, then use the clutch again at the bottom of the drive to back out into the street. Of course if your driveway is uphill that's not going to work too well, so you're left with riding the clutch or backing in.
I have to back up and turn as I exit my garage, so I need to go slowly. Just a little clutch engagement gets the car moving, and then I push the clutch peddle back down. I really don't even touch the brake.
Originally Posted by maj75
No, I just feather the clutch.
My driveway is sloped down, so I'll give it a try using the clutch only. I was a little concerned about causing damage to the clutch doing it that way. But it sound like it is okay.
Once you have 'mastered' the art of getting out of your garage and driveway (and since you have no experience driving a manual transmission), I suggest you find a safe, deserted, large, paved parking lot and simply practice...practice on deserted roads.
Proficiency driving the stick shift will come with time and experience. I worry if you are having problems simply backing-up you could put yourself and others at-risk driving in public. If you're stopped on a steep incline can you get-going easy enough without rolling backwards, without stalling the car or without having to accelerate rapidly? Go practice as much as possible....you'll get the 'hang of it' quickly.
I do pretty much the same thing everyone else has posted. It won't hurt the clutch to let it slip a bit and not let it all of the way out. I've been driving manuals for 30 years and my technique is so automatic, I had to think about it to try to answer your question.
Exiting (or entering) my garage is tricky because I have only about 3-4" clearance for the mirrors on both sides, and my driveway starts curving immediately outside my garage door. I think I ease the clutch out just enough to get the car moving, and then push it back in and coast very slowly until my mirrors clear the door frame, and then let it out again to add a little speed, then push it in again and coast and brake at the end of my driveway, then let it out again to back into the street.
Acutally, I have some time behind the wheel of the car, its more of the technique I'm trying to understand. I'm a little sloppy getting into first, but once I'm moving, things go good from there. Getting up my driveway is still a little tricky, but a friend of mine worked with me on holding the car with the brake until the clutch started to catch. I still need some pratice, but I'm getting better. I have backed up before in the street, but coming out of my garage was not comfortable. I thought the car was reversing to fast. I'm going to try it the next time using the clutch to regulate the speed.
Drive it. Think of what you do in 1st? Do the same in reverse EXCEPT when you get to the speed you are comfortable with, push the clutch to the floor and coast. If you start to lose momentum and need more "reverse" let the clutch out and speed back up to what you want then push the clutch to the floor. Hover your right foot over the brake if you're going down hill. Down hill is usually just get it started and let it roll.
From: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
2K7VETTE
I just feather the clutch out enough to get the car rolling slowly and then push it in and roll. I hardly ever let the clutch fully engage in reverse. I dont even need to give it gas. I just let the clutch out slowly and the car will start to move and rpms drop a little and then push it in and idle and roll.
If you are backing uphill more gas is needed and if downhill just roll.
It will not hurt it to feather the clutch when backing out.
