is there
Old Feb 22, 2007 | 09:35 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Default is there
a special tool to remove those fasteners in the wheel wells, or should aI continue to use a screwdriver and cuss??
Old Feb 22, 2007 | 09:37 PM
PAVette's Avatar
PAVette
After you bugger the first one with the screwdriver and you figured out the trick....the rest are easy! Good luck!
Sven's Avatar
Sven
St. Jude Donor '08-'09
just start with screwdriver, then switch to dikes (carefully) or long needlenose so you can get ahold of the whole thing. otherwise you're right ... it's like prying open a paint can ... lift one side and the other goes down.
Old Feb 22, 2007 | 09:38 PM
User 81424's Avatar
User 81424
Why?
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
Old Feb 22, 2007 | 10:03 PM
AP's Avatar
AP
Dude ... is there anything you do not have a tutorial for? job Ed
Old Feb 22, 2007 | 10:06 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Great Job ED !
Old Feb 22, 2007 | 10:07 PM
Radical05's Avatar
Radical05
I have a screw driver type tool I got a while back at a hardware store that at the end forks out and is perfect for removing the plastic pins. I imagine anyone would still have this item. No pic right now but it exist.
Old Feb 22, 2007 | 10:08 PM
cranky's Avatar
cranky
OR, you could take an old wide blade flat screwdriver and grind a "v" shaped opening in the flat end with your bench grinder and suddenly you have the correct tool for removal. ............cranky
Old Feb 22, 2007 | 10:10 PM
Pipedreams's Avatar
Pipedreams
Originally Posted by burtonbl103
Great Job ED !
Thanks, the nice part about the pliers is as you squeeze them they automatically pop out the pin since they are beveled: thumbs:
Old Feb 22, 2007 | 10:13 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Yes, there is a special removal tool. Can't find a pic of one right now though.
I've always used the can opener on my swiss army knife. The point gets under the pin, and the little hook in it does a good job of spreading the load out around the push pin's base
Found the pic. This is just one example:
Old Feb 22, 2007 | 10:16 PM
07MontRedcp's Avatar
07MontRedcp
Cussing will keep you grumpy. We love you the way you are!!
BJK
Old Feb 22, 2007 | 10:25 PM
Grumpy's Avatar
Grumpy
MONARTOR
Originally Posted by MAJ Z06
Why?
to remove them....
Old Feb 22, 2007 | 10:29 PM
5869vette's Avatar
5869vette
Default Don`t cuss !
Don`t cuss, cus the moderator [GRUMPY] will lock
this thread !
Old Feb 22, 2007 | 10:37 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Hey Grumpy...
Got a set of these and use them on C4, C6, and StuzVette
Old Feb 22, 2007 | 10:50 PM
shopdog's Avatar
shopdog
Yep, trim tool. Looks like a screwdriver with a forked end. Any auto tool shop should stock them.
Old Feb 22, 2007 | 10:54 PM
Radical05's Avatar
Radical05
That is exactly what I was talking about with the forked end. Works great.
To is there
Old Feb 22, 2007 | 11:02 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
Is this all for say putting a bra on? If it is I have a GM one that I want to put on and I hope it wount be to difficult.
Old Feb 22, 2007 | 11:06 PM
Wayne O's Avatar
Wayne O
CF Senior Member
This is great! I don't need to remove the wheel wells but I've had a tool similar to that 'large forked chingadera' for years. I used it once years ago to pry something or other....now I think I know what it was truly designed for.
Old Feb 22, 2007 | 11:35 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
This forum is great You ask a question and get a quick DIY from Pipedreams (BTW great job)
