Mud Guards
Old Feb 23, 2007 | 10:06 PM
talldude67's Avatar
talldude67
Default Mud Guards
Can the fender wheel well splash guard from a Z06 fit the stock C6 coupe wheel openings? Seems like that's the way to go if it works! Need Your Input.....thanks:
Old Feb 23, 2007 | 10:35 PM
07MontRedcp's Avatar
07MontRedcp
Here's what you're looking for. Enjoy
http://forums.corvetteforum.com/show...+splash+guards
BJK
Old Feb 23, 2007 | 10:44 PM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
also now that some time has gone by it would be nice to hear from all the members that installed them and the results
Old Feb 24, 2007 | 06:57 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
Good question Ed, I just asked the same question back in the original thread. Maybe if their thread is back on top, then they'll see it and respond.
Old Feb 24, 2007 | 07:51 AM
rjr2007's Avatar
rjr2007
Where do you get the Z06 splash guard? and what do they cost?
Old Feb 24, 2007 | 08:10 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
got mine from Fred Beans.. total was like $70.
Old Feb 24, 2007 | 08:11 AM
Pork Fat's Avatar
Pork Fat
That's down in the original thread as well. Form vendor Fred Beans.
Old Feb 24, 2007 | 11:33 PM
talldude67's Avatar
talldude67
Default Mud Guards 2
Just read RBYCC thread and will go with that...looks damn good tome....
Old Feb 25, 2007 | 09:20 AM
hayseed51's Avatar
hayseed51
Yeah, I also used the above excellent thread as a guide. What a great forum for help on projects like this!
In addition to the tape, I also did a couple of other things for attachment/sealing. When ordering the flaps, I also got some of those push-pins from GM (most auto parts stores have a selection too). After I had the flap in place, I drilled and installed a couple of these pins about half way up the inside edge of the flap (attach to the inner fender). Because the flap doesn't lay perfectly flat on the inner fender, I anticipated this would be a place that road crap would accumulate and bleed out, so I laid a bead of clear silicone in there. Just inside the inside edge of the flap, top to bottom. I did this before inserting the pins, but after drilling.
This extra stuff may not be necessary for a long-lasting install, but heck, it couldn't hurt either....
As far as durability, it's held up well for the 2 months they've been on. Sadly though, the vette's been in winter lay-up since Nov, so I guess it may be a little early to say for sure. Spring can't come soon enough!
Old Feb 25, 2007 | 11:06 AM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Hi All,
Just to let you know I sell them as well. You'll need a pack of 10 retainers to go with those. Just go to the site at www.gmpartshouse.com. Click where it says click here to enter part number search. Use part numbers 15818636, 15818637 and 11519444 x10 for the retainers under Chevrolet make.
Thanks,
Gene
Old Feb 25, 2007 | 01:12 PM
Pipedreams's Avatar
Pipedreams
Also if you go this route, I sell just my front splash guards since the Z06 don't work in the front and the front gets the worst damage.LINK
Old Feb 25, 2007 | 01:28 PM
Walt White Coupe's Avatar
Walt White Coupe
Originally Posted by Gene Culley
Hi All,
Thanks,
Gene
No retainers needed.
Old Feb 25, 2007 | 01:31 PM
07MontRedcp
3M VHB 4952 tape replaces the retainers.
BJK
Grumpy's Avatar
Grumpy
MONARTOR
I still have the fronts on.. work well..
To Mud Guards
