Pulley Problem video
Old Mar 4, 2007 | 07:16 PM
xstang's Avatar
xstang
Default Pulley Problem video
I'm thinking my pulley shouldn't move like this...
Old Mar 4, 2007 | 07:24 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Old Mar 4, 2007 | 07:28 PM
05dwived's Avatar
05dwived
You would be thinking correctly. Now for the warranty repair at the dealer
Old Mar 4, 2007 | 07:31 PM
shopdog's Avatar
shopdog
Or you could avoid the dealer and fix it correctly, with a pin.
Old Mar 4, 2007 | 07:32 PM
Sven's Avatar
Sven
St. Jude Donor '08-'09
Old Mar 4, 2007 | 07:36 PM
xstang's Avatar
xstang
I'm thinking about an underdrive pulley... What ever breaks make it better...
Old Mar 4, 2007 | 07:38 PM
Walt White Coupe's Avatar
Walt White Coupe
Check out this recent thread http://forums.corvetteforum.com/show....php?t=1635321
Chirping belt is the next thing you will probably have and then a pulley replacement because of a failed flex joint on the crank pulley. How many miles on the car?
Old Mar 4, 2007 | 07:41 PM
xstang's Avatar
xstang
It's already chirping.... quick stabs of the throttle....
Old Mar 4, 2007 | 07:47 PM
xstang's Avatar
xstang
14k miles
Old Mar 4, 2007 | 08:07 PM
Walt White Coupe
Staps on the throttle usually mean a loose belt usually caused by a failed belt tensioner pulley located just above where you took the video. I didn't notice that on mine but could be precursor to steady chirping at all speeds.
Old Mar 4, 2007 | 08:13 PM
xstang's Avatar
xstang
Hmmm, sounds like I have all kinds of issues
Old Mar 5, 2007 | 09:30 AM
xstang's Avatar
xstang
I dropped my car off at the delaership this morning... I'll keep you guys posted...
Old Mar 5, 2007 | 09:32 AM
not08crmanymore's Avatar
not08crmanymore
There was/is an open RECALL on pulleys,for EARLY 05's ANYWAY.
Old Mar 5, 2007 | 10:15 AM
shortski's Avatar
shortski
Looks like a loose crank bolt see this post for the TSB
http://forums.corvetteforum.com/show...01&postcount=2
Old Mar 5, 2007 | 10:21 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
1 RPM's worth of viewing would have me taking that car in to get it repaired.
Elmer
Old Mar 5, 2007 | 10:33 AM
xstang's Avatar
xstang
Elmer
The Service guy was looking at it and didn't think it was real bad... I got in my car and tapped the throttle... Then it started banging/knocking like in the video... He immediately knew something was wrong....
Old Mar 5, 2007 | 10:39 AM
eboggs_jkvl
Moderator emeritus
Service guys aren't always the sharpest pencil in the pack.
Elmer
To Pulley Problem video
Old Mar 5, 2007 | 10:44 AM
shortski's Avatar
shortski
Considering it's a know problem with a TSB out, that kind of says it all.
Give him this TSB # and have him look it up
#05-06-01-001A - (Feb 8, 2005)
Old Mar 5, 2007 | 10:57 AM
xstang's Avatar
xstang
They are fixing it... The Techs in the back were well aware of the pulley problems....
Old Mar 5, 2007 | 11:11 AM
Wayne O's Avatar
Wayne O
CF Senior Member
At least you got it to the dealership before you shredded your serpentine belt or even experienced further damage.
My harmonic balancer became out of alignment on my LPE 403 (with the stock crank-pulley). I have a theory why my pulley 'walked' but I did some research on the subject.
All of the Gen III and Gen IV V8 engines use a press-fit damper with no keyway which has been the case since the LS1 was introduced in 1997. With the 2006 model C6 and possibly with the late model 2005, GM began using a crank-pulley with an integral diamond-embedded (friction) washer (DEW). They also use a special 'stretch-to-yield' bolt which has to be torqued-down extraordinarily tight...I believe to 240 lbs. From what I learned, this special bolt cannot be re-used.
Assuming they will re-use your existing crank-pulley, I would make sure it has the integral friction washer and naturally, that a new bolt is used. Although I doubt the dealership would do this (especially under warranty) the tried and true method would be to pin the crank. Good luck on yours.
