performance questions
I Know very little about Chevy's new 360ci all aluminum small block. I have heard that Chevy did a pretty impressive job of wringing horsepower out of this engine, while still retaining a high degree of reliability.
My question is this; what can be done to find an extra 10 - 20 hp / ft lbs of torque without spending large sums of money or harming the engine?
Does this engine respond well to a K&N filter? Or does it make little difference? What fuel pressure works best in an otherwise stock engine - stock, or slightly modified? I like the Flowmaster Cat Back system I put on the '91. Does this engine respond well to such a system - or a different system? Doug Rippie reprogrammed chips do a very nice job on the C4s. Does recalibrating the "chip" on the C6s have the same impact?
I guess, in essence what I am after is maximizing the potential of an otherwise stock engine.
I would be interested in learning from anyone having experience - either good or bad - with any of these ideas.
Thank you in advance.
Glen
Glen
On the other hand, I have also heard that C6s are so quiet, that I figured they would respond well to opening up the exhaust a little bit. Again, I haven't bought the car yet. Just laying the groundwork for what I would be willing to pay "extra" for whe I start searching the net for the right car for me.
The C4s respond well to carefully reprogrammed chips, increased fuel pressure, and opened exhaust systems. I was just wondering if the C6s responded as well to these smaller modifications.
Glen
On the other hand, I have also heard that C6s are so quiet, that I figured they would respond well to opening up the exhaust a little bit. The C4s respond well to carefully reprogrammed chips, increased fuel pressure, and opened exhaust systems. I was just wondering if the C6s responded as well to these smaller modifications.
Glen
Some have added headers with stock mufflers and say its not loud.
I had headers installed with my Corsa mufflers and its not loud at all.
If you add headers with some other mufflers you might need ear plugs.
Couldn't find the dyno sheets for the stock and first set of mod but here's the dyno after the tune with the CAI and exhaust.
The biggest change in the dyno chart after the tune was in how quick the torque comes on. The stock tune didn't let the torque come on until 600-700 higher, also as part of the tune the shift points and shift firmness is adjusted so as to allow, lets say, for more spirited acceleration and much faster shifting, enough to chirp the tires on second and sometime third gear.
I did not know the C6s didn't have replaceable chips. Are the stock computer settings optimal for the type of minor enhancements I'm thinking of?
And Sven, I was under the impression that the 2005 was a pretty well sorted out car, with the exceptions being delamination of the roof panel, and apparently some difficulty with the radios. Are there other issues that were common to this model? In particular, my heart is set on a Daytona Sunset Orange coupe with the better brakes of the Z51 package, HUD, and Navigation system.
Thank you again for your replies. It helps a great deal to be able to reach a decision, and be willing to pay more for items that the first owner may already have added to the car.
Glen
Glen
This is really sorta funny, Glen. You're going to go from 240/250 HP to 400. You'll have all the increase in "bang for the buck" you can imagine.
I've got more than 350,000 miles in Corvettes and the C6 almost got away from me this past Friday. After the "fun" was over I thought: glad I was sort of expecting that, had I not been it would have been a whole different result.
After you've had your C6 for a while think about modding it.
JMO...
Same thing for the air cleaner housing. It flows very well. As proof, the car dyno's the same with it on or off. If you want colder (and wetter) air intake, there are simple and cheap (read free) mods you can do to the radiator shroud and air cleaner housing to get more ambient air. This may help with heatsoak caused timing pull at the drag strip, but still won't show any gains on the dyno or while cruising down the road. Save your money for something that matters.
A tune will net you gains. GM tunes the car rich, and uses a more conservative spark advance than you can get away with if you always burn good 93 octane gas. Gains of 10 to 15 hp (depending on altitude) are possible by tuning alone. A tuner can also remove some or all of the abuse mode torque management, which will improve throttle response and the slight tendency of the car to bog at shifts.
If you opt for the A4 automatic in your 2005, a tuner can also raise shift points and firm up the shifts, gaining you quite a bit of practical performance. Higher stall torque converters are also readily available for this time tested transmission.
The LS2 does respond well to a better flowing intake manifold (note, not air cleaner housing). You can install a FAST or Wieand manifold and see another 10 ponies on the dyno. Or you can have your stock manifold ported and see slightly lower gains. The latter is much less expensive.
The LS2 also responds very well to head and cam swaps. Crane makes some good "quick lift" cams for this engine, and you can add 1.8:1 rockers too (the latter may require a slight modification of the valve covers as well as better springs). The usual suspects, AFR, Dart, etc offer ported heads that perform well. A well chosen head and cam combo can net you 20-30 hp without adversely impacting your ability to use the car as a daily driver (more if you're building a race car).
The biggest change you can make that you can feel, however, is rear gears. Going to a 3.90 or 4.10 rear gear (in a manual, autos need less gear) will really wake the car up in daily driving. It will adversely impact gas mileage, though. The rear in the C6 isn't the most durable unit, so a diff swap to gain strength alone can be something to consider.
The brakes that come with the Z51 option aren't really better, except in the bling department. The standard rotors are more durable, and stop just as well. Racers often turn to the standard rotors when it is time to replace them (they're lots cheaper). Standard pads also dust much less than the Z51 pads, but are for the street only, switch to race pads for the track.
The Z51 suspension components are also a hot topic here. The antisway bars are great, and very inexpensive to add to a car with the standard suspension. The spring rates and shock valving aren't so great. The lower rate springs of the standard suspension actually work better on a car of this weight on real world roads, and ride better too. None of the factory shock offerings are good. Plan on installing Bilstein or Koni shocks to gain control of the car over less than perfect real world roads. They'll help control wheel hop at the drag strip too.
The downsides to buying a 2005 are the delaminating roof issue with the painted tops (also a problem with 2006s, but there's a recall under way to fix this), and the tendency to mysteriously kill the battery in the manual transmission cars (there is a reflash that kinda sorta fixes this).
Another minor issue is the "Doughboy" steering wheel. It is bus sized, and GM changed it to a smaller wheel for 2006 due to owner complaints. Originally, the Nav radio in the 2005s didn't play MP3s. There's a software update (which you can do yourself if you like) which fixes that.
An issue with all LS2s (and LS1s) is the unkeyed harmonic dampener's tendency to back out and walk off the crank. Consider pinning this to the crank as a preventative measure. Pinning kits are widely available. GM has their own "fix" for this, but it isn't well engineered. Pinning works.
Another annoyance with the C6 is the push button start "feature". It isn't as reliable and intuitive as a key. But it does have positive anti-theft characteristics. No one is going to be able to hot wire your car successfully. OTOH, you may lock yourself out, or be unable to start the car in some cases due to the quirks of the system. You'll have to adapt to it since it won't adapt to you.
The C6 is a really nice car, a step above the C5, and a huge leap above the C4. It has minor issues, but all cars do. Don't let them dissuade you from buying one.
There are inexpensive alternatives that will give you decent sound, you don't need to spend thousands, or turn your car into a ghetto thumper. Eclipse, Boston Acoustics, JL, etc all make nice reasonably priced speakers that work well in this car. A good 4 channel amp is needed too (the Blose is a highly colored 3 channel amp which outputs mixed mono to the rear and center dash speakers, killing the stereo soundstage). The HUs output 4 channels, so the wiring changes are easy. You don't need a lot of power unless you're building a ghetto thumper. 65 watts is plenty.
Glen
Wow, where to begin?
For what you are looking for, 10-20 RWHP/RWTQ, a cold air intake would be a good choice.
This is done through the car's OBD port or in the case of removing the ECM and sending it out for programming http://www.corvettec5.com/store/?page=shop/install (scroll down to the bottom of that page and it will show you where the ECM is located and how it is removed.)
http://forums.corvetteforum.com/show...30&postcount=1
Rather than argue about drilled rotors and such, I'll let you read up on your own. See what the SAE says about them
http://forums.corvetteforum.com/show...ghlight=rotors
Heres mine.
It sounds like a premium tune from a place like Doug Rippie Motorsports may offer me the most amount of performance for the money spent.
As one responder noted, I am going from a 250HP car to one with 400HP. This will certainly provide me with a performance "rush" that nothing I do afterward will equal. But as I orginally indicated, my goal was to maximize the performance of a stock engine. I equate maximum performance with maximum efficiency, mileage, responsiveness, etc.
Thank you to all who have so graciously taken the time to educate me.
Glen
Glen
Glen I wouldn't say exhaust mods are not worth the $. Typically with headers only and a dyno tune we get between 365 and 375 to the wheels with headers only flowing through the stock mufflers. A bone stock C6 will make about 340 plus or minus 5 to the wheels. So in saying that you can stand to gain upwards of 35 to the tires without any other mods. And if you ever were to step up to installing a head and cam package you will need the headers to get the most out of your investment. With a sleeper cam and cnc ported heads on a A6 C6 I netted 440 hp and 407 ft/lbs at the wheels, this is with a cam that sounds, drives, and idles like stock.
http://forums.corvetteforum.com/show....php?t=1629260
Definitely a lot of trade offs if you are talking about doing long tube headers.But the original poster mentioned that he was only looking for around 10-20 RWHP. That should not be hard to do at all.
Glen
Hey Glen....
For you....the best gains for the least amount of money would be our mail order tune.....
While we LOVE LG HEADERS and Vararams.....The best BANG for the BUCK is the tune.....
To the best of my knowledge there is no better way to improve the performance of your car for such a small amount of money...Also, for the guys who are on the fence about mods, thinking about trading the car in, or maybe driving a lease
car, my mail order tune is PERFECT for you....nobody will ever know!
Stay Tuned!
Chuck CoW
