2008 engine upgrade
Tom
Except the intent of DOD is improvement in fuel economy. Shutting off cylinders won't increase HP. It WOULD allow you to increase HP in some other way and then get back to better MPG while cruising. In any case, it doesn't belong in a performance car. GM tried it in the 80s and it was a total failure. They THINK they can make it work this time by better computer control of the engine. Blipping the throttle and such to match torque when changing cylinders. But how much can you gain? It takes a fixed amount of energy to move the air out of the way at speed. That translates into a fixed minimum amount of fuel. So now the question is, do you burn all that fuel in 4 cylinders or 8? If you are burning it efficiently to begin with it's hard to believe you can get more than a couple percent improvement in efficiency by burning it in 1 mass rather than 2. And the throttle blipping in stop and go traffic can't possibly be worth it. I must be missing something.But if you shut off 4 of them, you don't have to feed them at all. By closing the valves to those 4 deactivated cylinders, you also nearly halve engine pumping losses. So end result, when in DoD mode, you save up to half the fuel you'd have to burn if the engine didn't have DoD. But within 5 milliseconds of demanding more power, all 8 cylinders are back on line pulling their weight. You can't even feel that delay. It is roughly the time it takes your computer or TV screen to refresh once, and you don't see that flicker.
Of course it only saves you fuel when you're not accelerating. If you're demanding more power, fuel consumption goes back to what it would be without DoD. But most people run steady speed or decelerate for much longer periods than the time spent accelerating, so the overall fuel savings is significant, with no performance penalty. It is a clever idea, and in its current incarnation it works very well.
The old Caddies with the first generation DoD didn't have modern computer controls. Don't judge DoD by them. This new system is slick. It works seamlessly to effectively vary engine displacement according to load demand. Go drive a Yukon or Impala that has it, you won't be able to tell it is working unless you notice the light on the dash coming on and off.
Sounded like good news to me, in spite of shopdog's correct thermodynamic justification for using DoD.
