Getting headers coated
Old Mar 23, 2007 | 08:03 PM
Stingray55's Avatar
Stingray55
Default Getting headers coated
Would like to know if coating the inside of headers is necessary?
Does it reduce the inside diameter to the point of hurting performance?
What should I expect to pay to do the headers all the way back to exhaust?
Old Mar 23, 2007 | 08:06 PM
Wayne88's Avatar
Wayne88
Just my .02
It seems that coating the inside of headers will clog the cats if the inner coating starts to flake.
Old Mar 23, 2007 | 08:10 PM
lvjetboy's Avatar
lvjetboy
Coatings are relatively thin, insignificant change in xsect area or flow. Might help by keeping exhaust temp up and underhood heat down. Just a guess.
jer
Old Mar 23, 2007 | 09:04 PM
Batman7's Avatar
Batman7
Coating the inside of the headers is not necessary, most likely a waste of money. I guess the only reasons you would want to coat the exhaust all the way back is if you were showing the car or just want to know it looks nice. This is not a bad thing.
However, you don't want to keep the exhaust temps up too much by coating everything, especially if you are staying with using cats. You want some of the heat to escape as the higher temps can increase the likelihood of detonation and you don't want that.
I have a set of headers on order and I am just having the outside of them coated, then for my x-pipe I am just going to use the hi-temp ceramic based spray paint by duplicolor so it will look decent and cheap enough to repaint if I choose.
Old Mar 23, 2007 | 11:00 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I had my LGM long tubes coated. I've heard differing opinions on the benefits (or lack thereof) of coating headers. If for no other reason, I think it finishes them off nicely and I did not encounter detonation or other problems. I think the coating was in the neighborhood of $400.00. I'm happy with them both from an appearance and a performance standpoint.
Old Mar 23, 2007 | 11:02 PM
opus1111's Avatar
opus1111
I firmly believe coating exhaust components is a waste of money unless you do it for looks alone. Trusted drag racing and tuning friends told me this before I bought mine, and after install I believe it. I would've chipped the hell out of a couple places on them during my install... If you have any interference issues, you'll also be chipping the hell out of them.
I'm assuming you go with quality stainless headers, like 304 SS. Just my opinion- others will swear by coating. I chose to put the $$ into other mods.
Old Mar 26, 2007 | 04:41 AM
lvjetboy's Avatar
lvjetboy
I think Wayne88 has a good point. Flakes and cats may not be good. That said a good coating may not flake.
As for detonation? The post about letting some exhaust heat escape and so on to avoid detonation...not buying that.
jert
Old Mar 26, 2007 | 10:45 AM
Atomic-Vette's Avatar
Atomic-Vette
I had my headers coated on my previous supercharged car by Jet-Hot. they look great, I can't say for sure about under hood temps though. As for chipping them durring install, the coating is WAY more resielient than that. Unless you're using a hammer to do your install with you're not going to have any chipping problems. For the record my LG's for my Vette are going to be coated inside and out. Most quotes I've gotten for inside/outside of both headers is 250 bucks.
To Getting headers coated
