C6 display cluster question?
Old Apr 6, 2007 | 05:27 PM
Hunnicuttz's Avatar
Hunnicuttz
Default C6 display cluster question?
I have a 2006 C6 that I just took in on trade and on the guage cluster it has the previous owners name on it. Does anyone know how to remove this or switch it with a new name?
Old Apr 6, 2007 | 05:30 PM
Hoonose's Avatar
Hoonose
You have to go into the DIC personal settings. In the manual it will tell you how to change the readout, letter by letter.
Old Apr 6, 2007 | 05:34 PM
Hunnicuttz's Avatar
Hunnicuttz
Ok, i was just making sure that i dont need to take it by the dealership to get this fixed. Thanks!
Old Apr 6, 2007 | 05:35 PM
AFVETTE's Avatar
AFVETTE
Taken from page 3-75 and 3-76 of my 2006 Owners Manual
Personalize Name: This option allows you to type in a
name or greeting that will appear on the DIC display
whenever the corresponding keyless access
transmitter (1 or 2) is used or one of the memory
buttons (1 or 2) located on the driver’s door is pressed.
Press the OPTION button until PERSONALIZE NAME
appears on the display, then press the RESET button to
scroll through the following modes:
• YES
• NO (default)
If you choose YES, you can type in a name that will
appear on the DIC display.
To program a name, use the following procedure:
1. Enter the PERSONAL OPTIONS menu and select
the driver number (1 or 2) that you would like to
program by following the instructions listed
previously under “Entering the Personal
Options Menu”.
2. Press the OPTION button until the PERSONALIZE
NAME option appears on the display.
3. Select YES under PERSONALIZE NAME by
pressing the RESET button.
4. Press the OPTION button and a cursor will display
where you can insert a letter.
5. Press the OPTION button again until the letter you
want is displayed. To scroll through the letters
faster and without a beeping noise, keep the
OPTIONS button depressed. There is a complete
alphabet and a blank space available.
6. Then press the RESET button to select the letter of
your choice and proceed on to the next space to
the right. If you make a mistake and would like to clear or
replace a letter, perform the following steps:
6.1. Press the RESET button to reach the letter
you would like to change.
6.2. Press the OPTION button to scroll through
the letter choices.
6.3. Press the RESET button to select the letter
and proceed on to the next space to the right.
7. Repeat Steps 5 and 6 until the name or greeting
you want is complete. After the name or greeting
is complete, keep pressing the RESET button
until the display turns blank and exits out of this
option. You can program up to 20 characters.
If you choose NO, this option will turn off.
If a customized name or greeting is not programmed,
the DIC display will show Driver 1 or Driver 2 to
correspond with either the number on the back of the
keyless access transmitter (1 or 2) that is being used or
to the memory button (1 or 2) that is pressed.
PERSONALIZE NAME is the last option available to
program in the PERSONAL OPTIONS menu. Pressing
the OPTION button after this setting will exit you
from the PERSONAL OPTIONS menu. The last item
you were in prior to entering PERSONAL OPTIONS will
then display on the DIC.
Tom
Old Apr 6, 2007 | 05:43 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
• YES
• NO (default)
Options Menu”.
the letter choices.
Tom
Yep, Tom has you covered. That'll do the trick.
Old Apr 6, 2007 | 05:53 PM
Hunnicuttz's Avatar
Hunnicuttz
Wow Thanks Tom!!!
Old Apr 6, 2007 | 10:10 PM
Lightning Coyote's Avatar
Lightning Coyote
Have fun!
To C6 display cluster question?
