WBS not DBS this Time
Any recommendations? Optima? Interstate? Delco?
Either red or yellow top, hands-down.
Can't go wrong with the Optima.
Plus if I had an '05 MN6 car?
A battery tender hooked-up whenever parked for extended periods of time, regardless the make of battery.
I recall reading a post that leads me to believe GM is finally figuring-out what is causing the problem. Hopefully a true fix is in-the-works.
My response was prompted by this poster sounding as though he DID have an actual case of, "DBS".
Neglected considering not all, like you, have had this happen with their '05s.
I'm still smarting from the lousy Delco my '03 AE had.
Now as in [that] case I just took the initivive to replace the stock battery with an Optima (Redtop), before there ever was a chance of my being stranded.
Let us hope because those who purchased an '05 in good faith only to expereince this abomination, deserve better.
